Archive for September, 2004
Sep
30
Last Day of September 2004
Hi all,
Started the morning with a:
2002 Frigidaire Top Freezer Refrigerator: Not cooling, Found the compressor burn out and restriction in filter drier of sealed system.
Ordered both parts.
Under the 5 yr. part and labor warranty.
Frigidaire Compressor
Filter Drier
2003 Frigidaire Front Load Washer: Tub not spinning in wash and spin cycle, Found Motor Controller Board out, replaced board, worked great.
2003 Whirlpool Slide-In Gas Range: Shows F1 code(oven door locked) Found bad electonic control board, ordered.
1998 Kitchen Aid Dishwasher: Motor not coming on, Found bad micro-computer board, ordered.
Thats it today!
Have a good evening!
South Willamette Valley, Oregon forcast:
Tonight. Mostly clear. Lows around 45. Northwest wind 5 mph becoming light.
Friday. Partly cloudy with areas of fog in the morning. Then becoming mostly sunny. Highs 75 to 80. Light wind becoming northeast 5 to 15 mph.
Categories : The Daily Diary
Comments (0)
Sep
29
Maytag Ranges
Maytag® Gas Range
Largest oven capacity available! Cook the appetizers, main dish, side dishes and dessert all at once.
5.22 cu. ft. capacity – much larger than other brands, with cooking space for large dinners and special events
Precision Cooking™ System with PreciseBake – for even baking and browning. Maytag bakes it even better!**
DuraClean™ design – sealed surface burners, lift-off burner caps, DuraClean™ cast iron burner grates, DuraClean™ smooth gloss backguard and hidden bake burner for easy cleanup
Maytag® Electric Range
Precision Touch 500 Electronic Controls with Precise Preheat – easy to read and operate; alerts you based on actual temperature, not a preset time, for accuracy and better results
Self-cleaning oven with adjustable levels – allows you to match cleaning level to the amount of food buildup in the oven
High-wattage coil elements with porcelain drip bowls – wipe clean easily to keep kitchen sparkling; provide high-wattage response for better performance
DuraClean™ porcelain-on-steel control panel and surface – take a hard scrubbing without scratching, so it’s easy to keep them looking clean and new
More on Maytag Ranges Click Here
Good Ranges, very few repairs!
Tonight. Mostly cloudy. Lows around 45. Northwest wind 10 to 15 mph early in the evening becoming light.
Thursday. Decreasing clouds. Highs 70 to 75. North wind 10 to 15 mph.
Categories : Ranges
Comments (0)
Sep
28
New Frigidaire Dishwasher
The morning low clouds and fog burned off alot earlier this morning, made for a wonderful sunshine filled day here in Springfield, Oregon.
Frigidaire®, a leader in home appliance innovation, announces a quantum leap in dishwashing technology with the introduction of its SpeedClean™ dishwashers. By incorporating the revolutionary AquaSurge™ technology, you can now adjust the washing pressure for various dishwashing needs. Frigidaire® dishwashers can truly deliver on the promise of faster, quieter, cleaner dishwashing.
Frigidaire speed clean dishwasher
The sleek, semi-integrated design of our new SpeedClean™ dishwashers provide a clean exterior appearance, symphonizing primary control functions onto the top of the door, displaying only the innovative “Favorite Cycle” and “Start” functions on the front, along with the “Cycle Status Indicator.” Most controls, including “Child Lock,” are now out-of-sight and out-of-reach.
You can read more on this new dishwasher, just click here.
Looks like a good dishwasher. We will see how customers like it.
Tonight. Clear in the evening. Then becoming partly cloudy. Lows 45 to 50. Northwest wind 10 mph in the evening becoming light.
Wednesday. Mostly cloudy in the morning. Then becoming partly sunny. Cooler. Highs around 70. Northwest wind 10 to 15 mph.
Categories : Dishwashers
Comments (0)
Sep
27
Monday Sept. 27th
Hi all,
The morning low clouds did burn off this afternoon, very nice fall day here in Springfield, Oregon.
1998 Frigidaire Upright Freezer: Not Cooling, Found Compressor burn out, compressor oil restricted in evaporator, heat exchanger, filter drier.
Spent 4 hours this morning changing all those parts plus installing the new drain pan kit that solders to the condenser tubing(high side) of the compressor that heats the defrost drain water to evaporation. No charge to customer, under the extended warranty contract they purchase yearly. If they didnt have the contract it would have cost close to $1000 to repair, very labor intensive job!
Frigidaire 20.3 cubic feet-MFU20
1992 Whirlpool Dryer: Not heating properly, Found cycling thermostat out, replaced cycling thermostat, worked great.
Thats it today!
Tonight. Mostly clear. Patchy fog after midnight. Lows around 50. North wind 10 mph early in the evening becoming light.
Tuesday. Areas of clouds and fog in the morning then mostly sunny. Highs 80 to 85. Light wind becoming northwest 10 mph in the afternoon.
Sunset in Moab, UT
Sunset in Moab, UT
Comments (0)
Sep
26
Sundays Events
Posted by: Jake | Comments (2)
Hi all,
The morning clouds almost burned off today in the Eugene/Springfield, Oregon area.
Started this morning with a:
2002 Maytag Front Load Washer, this is the 2nd rubber door boot i have put on this unit in 2 yrs. this is un-heard of. Something is making the rubber boot mold and mildew badly. Under extended warranty.
2002 Maytag Top Load Washer: Making strange noises, Found timer very load clicking sounds and water pump bearing squeaking bad. Ordered Parts. Under extended warranty.
Maytag® Atlantis® Washer
1994 Maytag SxS Refrigerator: Not Cooling properly, Found frost build up on back freezer panel, needs defrost heater assembly, ordered.
Maytag® 23 cu. ft. Side-By-Side Refrigerator
Thats it today!
Tonight. Partly cloudy in the evening. Then mostly cloudy with areas of fog after midnight. Lows 50 to 55. North wind 10 to 15 mph early in the evening becoming light.
Monday. Areas of morning clouds and fog. Then sunny. Highs around 85. Light wind becoming north 10 mph in the afternoon.
Comments (2)
Sep
25
Super Saturday Sept. 25th
The low clouds stayed all day, never burned off here in Eugene/Springfield, Oregon area.
2002 Sears Kenmore SxS Refrigerator(Whirlpool built): Ice maker not working, Found the black rubber fill spout on the freezer ceiling that supplies water to the ice maker was frozen, de-iced the rubber spout, worked great. No charge, Extended warranty.
2004 Maytag Front Load Washer: The customer was complaining about the door not being aligned properly with the cabinet. This is normal. It will never leak from the door. If you go to any new appliance store where they sell these new, you will see they are all like that. Under 1st yr. warranty.
1982 Sears Kenmore Top Freezer Refrigerator(Whirlpool built): Not cooling, Found the condenser fan motor not turning, 1 of the fan blades was jammed in the fan shroud. Reset the fan blade, worked great. Cost $65.00
2004 Whirlpool SxS Refrigerator: Not cooling in refrigerator section, Found ice/frost build up in air supply and return ducts. The Freezer door was not closing properly causing this. Reset the ice bucket(was keeping door from closing all the way) , cleared and defrosted all ice/frost, worked great. Under 1st yr. warranty.
Thats it today!
Tonight. Mostly cloudy. Lows around 50. Northwest wind 5 to 10 mph early in the evening. Becoming light overnight.
Sunday. Partly sunny. Highs 75 to 80. Light wind becoming north 10 to 15 mph in the afternoon.
Cathedral Peak
Cathedral Peak
Yosemite, CA
Comments (0)
Sep
24
Sunny Friday
Hi all,
2003 Sears Kenmore Dryer(Whirlpool built): Making metal squealing noise while running, Found idler bracket bad, replaced with a rollor style idler pulley, worked great. Under 1 yr. warranty.
Kenmore dryer idler pulley part#691366
2004 Sears Kenmore Washer(Whirlpool built): Water on hot side not coming in, just trickling in. Found bad water valve on washer. Ordered. Under 1 yr. warranty.
1995 Sears Kenmore Dryer(Whirlpool built): Not heating, Found heating element out, also saw customers vent hose from dryer kinked and kinda crushed, which would contribute to more wear on the heating element.
Cost to repair about $175.
2002 Sears Kenmore Dryer(Whirlpool built): Drum turning slow when started, then the dryer just shuts off, Found Motor bad. Under a extended warranty, No charge.
Kenmore dryer motor part#279787
Thats it today!
Tonight. Mostly clear. Then areas of low clouds and patchy fog late. Lows around 55. Light wind.
Saturday. Mostly cloudy with areas of morning fog. Then mostly sunny in the afternoon. Highs around 75. Northwest wind 5 to 10 mph.
Comments (0)
