Archive for December, 2004
Dec
17
Fill Hoses on Washer
1990 Sears Kenmore Washer(Model#11081910100): Found a bubble starting to form in one of the rubber fill hoses that connect to the washer.
I use the new Universal Stainless Steel Water Fill Hose to replace these now. You can buy them in just 1, or a pair, Its always better to change both if you change 1.
587617
5-foot braided stainless steel fill hose for either hot or cold water inlet hose. Stainless steel can handle higher water pressure and is less likely to burst. The hose is flexible, can’t crimp and is easy to install.
2 Stainless Steel Washing Machine Hoses, 6 feet long
1012448
Use these pro grade, braided stainless steel hoses to connect your washing machine to the water supply. These hoses will replace any standard black rubber washing machine hose. 4 rubber washers included.
Have a Good Weekend!
Forecast for South Willamette Valley
Issued: December 17, 2004 21:07:59 PST
Tonight: Mostly cloudy. Areas of fog becoming dense at times. Lows 35 to 40 light wind..
Saturday: Mostly cloudy. Areas of morning fog…dense at times early…then patchy fog in the afternoon. Highs in the mid 40s light wind.
Categories : The Daily Diary
Comments (0)
Dec
17
240v Dryer Cord
1992 Sears Kenmore Dryer(Model#11096110100): Not Heating, Found one of the hot 120v Dryer Cord Wires Broken in the dryer terminal block connection, that hooks up to the 240v power outlet. I Installed a new Dryer Cord, worked great. This will take a Universal Dryer Cord.
Universal Dryer Cord – 3-wire, 30 amp, 6 foot
12900
Comments (0)
Dec
17
Washer Timer
2004 Sears Kenmore Washer(Model#11015962400): Not Spinning on the low speed selection, Found the timer bad, I Installed a new timer, worked great, Part#8541110
Timer
1018683
Comments (0)
Dec
17
Dryer Heating Element
2000 Sears Kenmore Dryer(Model#11060942990): Not Heating, Found the heating element went out, I Installed a new one, worked great. Part#3387747.
Heating element assembly
525502
Comments (0)
Dec
17
Dishwasher Detergent Dispenser
2000 Whirlpool Dishwasher(Model#GU940SCGB2): The Detergent Dispenser door was not latching properly, worn out. Installed a new Dispenser Latch Cover Kit Assembly, Part#4387043. Worked great.
Detergent cup dispenser cover, spring, pin and latch
3276
Comments (0)
Dec
17
Maytag Dishwasher Motor
2003 Maytag Dishwasher(Model#MDB7600AWW): Making a bad noise in the wash cycle, Found the motor shaft out of round when turning, Part#99002980. I Installed a new motor/pump assembly, worked great.
Wash motor assembly
Comments (0)
Dec
16
Condenser Fan Motor and Compressor Relay
2000 Whirlpool Side by Side Refrigerator(Model#GD25DIXHW00): Not Cooling, Found the condenser fan motor was out and the compressor relay was out too, due to the extra heat load on the compressor and condenser with the condenser fan motor not working. Installed a new condenser fan motor, Part#833697
Condenser fan motor kit, 2 Watt clockwise rotation, hardware and instructions included
2790
Also Installed the compressor relay and overload kit, Part#4387535
Compressor relay & overload assembly
586234
Have a good evening!
Issued: December 16, 2004 21:06:50 PST (ORZ008)
Tonight: Cloudy. Areas of fog developing…locally dense. Lows in the mid to upper 30s light wind..
Friday: Mostly cloudy. Areas of fog in the morning…then patchy fog in the afternoon. Highs in the mid to upper 40s light wind.
Comments (0)
