Archive for January, 2005
Control Panel Assembly
Posted by: | Comments2004 GE Oven(Model#JRS04B0W2BB): Beeping when unit is not even on, touchpad has a short in it, Part#WB36T10076
Touch pad and control panel assembly, black
(The manufacturer has replaced part number WB36T10076 with this item, part number WB36T10544.)
Have a good evening and weekend!
Forecast for South Willamette Valley
Issued: January 14, 2005 21:53:53 PST
Tonight: A chance of rain. Rain likely overnight. Pockets of freezing rain possible. Temperatures overnight 30 to 35. Northeast wind to 10 mph.
Saturday: Rain at times. Highs 40 to 45. Southeast wind 10 to 15 mph.
Dishwasher Chopper and Check Valve
Posted by: | Comments2004 Kitchen Aid Dishwasher(Model#KUDI01ILWH3): Not cleaning well, found the chopper and check valve bad, Chopper Part#8268383
Chopper
Check Valve Part#8268375
Check valve, pump sump
Have a good evening!
Issued: January 13, 2005 20:55:02 PST
Tonight: Partly cloudy early…then mostly cloudy after midnight. Areas of fog after midnight. Lows 30 to 35 light wind..
Friday: Mostly cloudy early…then mostly sunny in the afternoon. Areas of fog in the morning. Highs around 40 light wind.
Refrigerator Air Cleaner
Posted by: | CommentsCompressor Relay/Overload Kit
Posted by: | Comments2000 Sears Kenmore Refrigerator(Whirlpool built)(Model#10650269991): Not cooling at all, Found the condenser clogged solid and the compressor relay burned out, I Cleaned the condenser and installed a new compressor relay/overload kit, Part#4387535
Compressor relay & overload assembly
Issued: January 10, 2005 21:45:26 PST
Tonight: Partly cloudy early…then mostly cloudy after midnight. Areas of fog after midnight. Lows around 30 light wind..
Tuesday: Mostly cloudy early…then partly sunny in the afternoon. Areas of fog in the morning. Highs 40 to 45 light wind.
Drain Pump
Posted by: | Comments2003 Sears Kenmore Front Load Washer(Frigidaire built)(Model#41743142200): Load noise from the water pump when draining, Found the pump bearing bad, I Installed a new pump, Part#134051100
Drain pump and motor asssembly
Water Valve and Water Filter
Posted by: | Comments2000 Sears Kenmore Side by Side(Whirlpool built)(Model#10659507993): No water to the ice maker and water dispenser, Found the water valve had gone out, Part#4389177
Water inlet valve kit with new quick connections and instructions
Also the water filter had not been changed in more than 1 yr.
The customer bought a new water filter, Part#4396508
Ice and water filter in front access grille for refrigerators made by Whirlpool, including some Kitchen Aid and Kenmore refrigerators. This is manufacturer part 4396508, and it replaces 4392857, WF-NL300, WF-L500 and 4396163. Replace every 6 to 12 months.
Issued: January 09, 2005 14:57:50 PST
Tonight: Mostly cloudy with a chance of showers. Lows in the mid 30s. South wind 10 mph early in the evening becoming southeast 5 to 10 mph after midnight.
Monday: Mostly cloudy with a chance of showers. Highs 40 to 45. Light wind becoming northeast 10 mph in the afternoon.
GE Dryer Rotary Turn to Start Switch
Posted by: | Comments1999 GE Dryer(Model#DCXR453EV0WW): The Rotary Turn to Start Switch was malfunctioning and not coming on at times till you turned the switch very slowly, Part#WE4X881
Rotary start switch
Issued: January 08, 2005 21:02:00 PST
Tonight: Showers likely. Snow level near 1000 feet. Lows around 35. South wind 10 to 15 mph.
Sunday: Showers likely. Highs 40 to 45. Snow level near 1000 feet. South wind 10 mph.
