Archive for February, 2005
GE Dishwasher Solenoid
Posted by: | Comments2003 GE Dishwasher(model#GSD1100G00WW): Not Draining the water out, I found the Drain Pump Solenoid bad and melting some of the inner plastic, Part#WD21X10060.
Dishwasher drain solenoid kit
Have a good evening!
Forecast for South Willamette Valley
Issued: February 17, 2005 21:28:46 PST
Tonight: Mostly clear. Lows around 30. North wind 10 mph.
Friday: Mostly sunny. Highs around 55. Northeast wind 10 mph in the morning..becoming light wind in the afternoon.
Control Board and Frame
Posted by: | Comments2004 Kenmore Front Load Washer made by Frigidaire(model#41744072300): The Control Panel display lights flickering at different times, even when the washer was not in use. This is the second one of these i have seen do this in 6 months. This is a new upgrade model washer than the previous. I installed a new Control Board, and Console Frame(which includes the touchpad). Worked Great.
Control Board, Part#134207700
Console Frame(which includes the touchpad), Part#134208200
Dishwasher Cleaner and Deodorizer
Posted by: | CommentsI have alot of people ask me, What should i use to remove the soap scum build up in the dishwasher and washing machine? I recommend this product. It works great.
Get your dishwasher sparkling clean and lemon fresh. Removes built-up soap scum and discoloration due to iron and other water impurities. Also works great in washing machines, porcelain sinks and porcelain tubs. 3 ounce packet.
Glisten Dishwasher Cleaner and Deodorizer
Front Load Washer Motor
Posted by: | Comments2000 Frigidaire Front Load Washer(Model#FWT449GFS2): Motor not turning in wash and spin cycles. Found the motor bad. Part#131276200 There is a tech. sheet inside the washer front access panel. It gives step by step checks in detail.
Main drive motor
Issued: February 13, 2005 21:22:11 PST
Tonight: Mostly cloudy with a chance of showers. Patchy fog after midnight. Lows 30 to 35 light wind..
Monday: Mostly cloudy early…then partly cloudy in the afternoon. Patchy morning fog. Highs around 50. Light wind…becoming north to 10 mph in the afternoon.
Dryer Duct Brush
Posted by: | CommentsThis Dryer Duct Brush is great to help clean out your dryer exhaust duct to keep the air flow at top performance.
Use this brush to conveniently clean accumulated lint out of the dryer vent.
Vent Brush For Cleaning 4-inch Round Dryer Vent 20 foot
Roller and Belt
Posted by: | Comments1995 Sears Kenmore Dryer made by Whirlpool(Model#11096588210): Making a loud rattle sound when the dryer is running, I found one roller on the front bulkhead bad, Roller Part#8536974. Also the belt was wearing out with many cracks starting to show. Belt Part#661570.
Drum support roller kit
Belt Part#661570
Dryer belt, length 93 1/2”, width 1/4”, characteristics, 4 ridges, flat
Whirlpool Chopper and Check Valve
Posted by: | Comments2002 Whirlpool Dishwasher(Model#GU1200XTKT0): Making a bad grinding sound when washing, found the chopper and check valve bad, Chopper Part#8268383
Chopper
Check Valve Part#8268375
Check valve, pump sump
Have a good evening and weekend!
Issued: February 11, 2005 21:42:01 PST
Tonight: Increasing clouds with a chance of rain late. Patchy fog late in the evening. Lows 35 to 40. South wind 10 mph.
Saturday: Rain likely early…then showers likely in the afternoon. Highs around 50. Southwest wind 5 to 15 mph.
