Archive for April, 2005
Kenmore Even Heat Dryer
Posted by: | Comments2000 Sears Kenmore Even Heat Dryer made by Whirlpool(model#11060097990): Stops prematuring before the clothes are dry, Found the control board bad, Part#3978696.
Electronic control board
We have been talking about this Topic in Our Forum for awhile.
Have a good evening and weekend!
Forecast for South Willamette Valley
Issued: April 29, 2005 21:42:11 PDT
Tonight: Mostly cloudy with a chance of showers. Lows 45 to 50 light wind..
Saturday: Mostly cloudy with a chance of showers. Highs 60 to 65. Light wind becoming northwest 5 to 10 mph in the afternoon.
Kenmore Range Broil Element
Posted by: | Comments2000 Sears Kenmore Range made by GE(model#91195402000): Broil element shorted out and snapped the element in half, Installed a new one, worked great, Part#WB44T10009.
Broil element
Have a good evening!
Issued: April 28, 2005 21:03:07 PDT
Tonight: Mostly cloudy. A slight chance of showers late. Lows around 50. Southwest wind 5 to 10 mph.
Friday: Mostly cloudy with a chance of showers. Highs around 60. Southwest wind 5 to 10 mph.
Front Load Washer Shock Absorber
Posted by: | Comments2002 Sears Kenmore Front Load Washer made by Frigidaire(model#41742042100): Making a load banging sound at the end of the spin cycles, Found the right side shock absorder broken, I installed a new one, worked great. Part#131268200
Tub leveling shock absorber
Issued: April 26, 2005 21:34:38 PDT
Tonight: Mostly clear in the evening then becoming partly cloudy. Patchy fog after midnight. Lows 45 to 50. Northwest wind 5 to 10 mph.
Wednesday: Partly cloudy. Patchy fog in the morning…then a slight chance of thunderstorms in the afternoon. Highs around 70. North wind 5 to 15 mph.
Sears Kenmore Washer Leaking Oil
Posted by: | Comments2001 Sears Kenmore Washer made by Whirlpool(model#11024932200): Leaking oil underneath on the floor, Found the Transmission(Gearcase)Leaking Oil, Part#3360629. Installed new Gearcase, worked great. Under 5 year warranty for the part only. Consumer only charged for the labor.
Gearcase for direct drive washer(The manufacturer has replaced part number 3360630 with this item, part number 3360629.)
Issued: April 25, 2005 21:19:16 PDT
Tonight: Partly cloudy. Patchy fog after midnight. Lows around 45 light winds..
Tuesday: Areas of clouds with patchy fog in the morning…then partly sunny. Highs around 70. Light wind becoming north 10 to 15 mph in the afternoon.
Speed Control Board
Posted by: | Comments2003 Frigidaire Front Load Washer(model#GLTF1040AS0): Not spinning at times in the final spin cycle,
The problem is the speed control board that will have to be replaced. I installed a new one, it worked great. Part#134306000
Spin control board assembly
Issued: April 24, 2005 21:23:22 PDT (ORZ008)
Tonight: Mostly cloudy with a chance of showers. Lows around 45 light winds..
Monday: Mostly cloudy in the morning then becoming partly sunny. A slight chance of showers. Highs around 65. North wind 5 to 10 mph.
Water Valve Kit
Posted by: | Comments2000 Sears Kenmore Side by Side Refrigerator made by Amana(model#59658692890): Leaking water when someone gets water from the front water dispenser, Found the “Y” connector broken that comes out of the water valve, Part#R0000242
Dual water inlet valve, primary (before water filter). Replaces problematic plastic “Y” connector, includes instructions
Issued: April 22, 2005 21:35:34 PDT
Tonight: Partly cloudy. A slight chance of thunderstorms in the evening…then isolated showers after midnight. Lows around 50. Light wind becoming south 5 to 10 mph after midnight.
Saturday: Mostly cloudy with scattered showers. A slight chance of thunderstorms in the afternoon. Highs around 65. South wind 5 to 10 mph shifting to the west in the afternoon.
Overload/Relay
Posted by: | Comments2001 Sears Kenmore Side by Side Refrigerator made by Whirlpool(Model#10650202993):Not Cooling at all, clicking sound can be heard in the back of the refrigerator, The Compressor Relay has gone out, Part#4387535. I installed a new one, worked great.
Compressor relay & overload assembly
Issued: April 21, 2005 16:31:28 PDT
Tonight: Partly cloudy with a slight chance of thunderstorms in the evening…then mostly clear after midnight. Lows around 40. North wind 5 to 10 mph.
Friday: Patchy morning fog or low clouds otherwise mostly sunny. Highs 70 to 75. Light wind becoming north 10 to 15 mph in the afternoon.
