Archive for April, 2005
Washer Coupler
Posted by: | Comments1999 Sears Kenmore Washer made by Whirlpool(model#11029852991): Not Spinning, Found the Motor/Gearcase Coupler broken, Part#285753.
Drive motor to transmission coupling, replaces all previous styles and versions. For direct-drive washers with no belt.
Glisten
Posted by: | CommentsThis is a great cleaner, on sale this week!
Get your dishwasher sparkling clean and lemon fresh. Removes built-up soap scum and discoloration due to iron and other water impurities. Also works great in washing machines, porcelain sinks and porcelain tubs. 3 ounce packet.
Glisten Dishwasher Cleaner and Deodorizer
Have a good evening!
Forecast for South Willamette Valley
Issued: April 18, 2005 20:44:13 PDT
Tonight: Partly cloudy. Patchy fog late. Lows around 35. Evening northwest wind 5 to 10 mph.
Tuesday: Partly sunny in the morning then clearing. Patchy fog in the morning. Highs around 65. Light wind becoming north 10 to 15 mph in the afternoon.
Oven spark ignitor
Posted by: | Comments2004 Whirlpool Range(model#GS475LEMS0): Oven not coming on, Found when you turned the oven on, the oven spark module would click but the ignitor would not spark, The problem is the oven spark ignitor, Part#8190618
Oven bake burner tube assembly with spark igniter
*Igniter is only available with this assembly.
Issued: April 16, 2005 20:45:01 PDT
Tonight: Partly cloudy. A slight chance of showers. Lows around 40. Southwest wind 5 to 10 mph.
Sunday: Showers. Highs around 55. Southwest wind 5 to 15 mph.
Blower Wheel
Posted by: | Comments2004 Sears Kenmore Dryer made by Whirlpool(model#11085872400): Making a bad noise and not drying properly, leaving some condensation on the floor, Found the Blower Wheel stripped from the motor shaft, causing a slow speed blower rotation and lots of rattling noise. Part#697772
Dryer blower wheel
Have a good evening and weekend!
Issued: April 15, 2005 21:45:25 PDT
Tonight: Rain at times. Lows around 45. South wind 5 to 15 mph.
Saturday: Rain in the morning…then showers likely in the afternoon. Highs in the mid to upper 50s. Southwest wind 5 to 15 mph.
Drain Pump
Posted by: | Comments2005 Sears Kenmore Front Load Washer made by Frigidaire(model#41744152400): Making a very load vibration noise when the Drain Pump starts, Found the Drain Pump Bearing bad, Drain Pump Part#134051200
Drain pump and motor assembly
Issued: April 14, 2005 21:18:17 PDT
Tonight: Partly cloudy early then becoming mostly cloudy. Lows around 35 light wind..
Friday: Mostly cloudy with a chance of rain. Highs around 60. Southwest wind 5 to 10 mph.
Washing Machine Tray
Posted by: | CommentsFits most standard, large, and extra-large washers. Optional floor drain connection included. Tray dimensions: Inner dimension – 27 inches x 30 inches (Outer dimension – 30 inches x 32 inches) x 2 inches deep.
Washing Machine Water Spill / Leak Preventer Floor Tray
Tonight…Partly cloudy with scattered showers. Lows around 35. South wind 10 mph.
Thursday…Partly cloudy with a slight chance of showers. Highs around 55. Southwest wind 10 mph.
Complete Garbage Disposer
Posted by: | Comments1/2 HP garbage disposer manufactured by Whirlpool. Made with a continuous-feed, galvanized steel grinder, quick-lock flange mount and fully insulated for quite operation. Does not include power cord.
Designed with a continuous feed galvanized steel grinder with anti-jam wrench.
Garbage Disposer – 1/2 HP
P/N: 84211601
