Archive for May, 2005
May
30
Water Filters on Sale this week
With the price of water filters on the rise the past several years, its hard to pass up a good sale.
Water Filter Sale
Water Filter Sale
Categories : Refrigerators
Comments (0)
May
27
Water Level Switch
1997 Sears Kenmore Washer made by Whirlpool(model#11026842691): Everytime you start the washer to fill with water, it will not fill, it starts agitating, then when you move the knob to reset, it starts filling with water. This washer will need a new water level(pressure) switch.
Part#3366845
Water fill level switch
2697
Have a good Memorial Day Weekend!
South Willamette Valley
Issued: May 27, 2005 22:08:12 PDT
Tonight: Partly cloudy with a slight chance of thunderstorms after midnight. Lows around 55. Southwest wind 5 to 10 mph.
Saturday: Partly sunny. A slight chance of showers in the morning…then a chance of thunderstorms in the afternoon. Not as warm. Highs 75 to 80. Southwest wind 5 to 10 mph.
Categories : The Daily Diary 2
Comments (0)
May
25
Water Filters
Posted by: Jake | Comments (2)
Its good to change the water filter every 3-6 months in hard water area’s, and 6-12 months for other area’s the water is not as hard.
Here is a picture and link to the new style Frigidaire/Westinghouse and Sears Kenmore made by Frigidaire water filters.
PureSource2 Water Filter
P/N: WF2CB
WF2CB
PureSource2 Filter fits all Frigidaire / Westinghouse refrigerators that have a slide-out filter cartridge in the front of the refrigerator compartment. Replaces part numbers FC-100, FC100, and Kenmore part 46-9911.
This will reduce the following contaminants: 99.99% of cysts, 98.5% of particulates (Class I), 99.70% of turbidity, 99.30% of lead, 98.6% of particulates (Class III), 91% of mercury, 96% of 1,4-D (a herbicide), 98% of Alachlor (a herbicide), 98% of Atraxine (a herbicide), 92% of Lindane (a pesticide), and 87.5% of Toxaphene (a pesticide).
Comments (2)
May
23
Sears Kenmore Washer/Dryer Stackable
2005 Sears Kenmore Washer/Dryer Stackable Laundry System made by Frigidaire(model#41794812301): Making a very loud noise in the washer spin cycle, I found the lockplate to the transmission spin shaft loose, and the belt was burned abit, I reset and tightened the Lockplate Bolts and installed a new belt,
Part#134161100
Drive belt, washer
936919
Have a good evening!
Issued: May 23, 2005 21:35:39 PDT
Tonight: Clear. Lows 40 to 45. North wind 10 to 15 mph becoming light after midnight.
Tuesday: Sunny. Highs around 75. North wind 5 to 15 mph.
Comments (0)
May
22
Even Heat Control Board
2002 Sears Kenmore Dryer made by Whirlpool(model#11063932101): The problem is when pushing the start button, it starts then when you release the start button it stops. Found the Control Board bad, Part#8546229
1028313
Issued: May 22, 2005 21:46:25 PDT
Tonight: Partly cloudy with isolated showers ending by midnight.. Then clearing. Patchy fog late. Lows near 40 light wind..
Monday: Mostly sunny. Patchy morning fog. Highs near 70. Light wind…becoming north 5 to 10 mph.
Comments (0)
May
19
Refrigerator Water Valve
2002 Frigidaire Side by Side Refrigerator(model#FRS23K7AW5): Not filling ice maker when the ice maker cycles for more water. I found the Water Valve didnt Ohm out properly, no continuity through the coil.
Part#240531101
Water inlet valve assembly
937309
Issued: May 19, 2005 21:18:13 PDT
Tonight: Showers likely. Lows 45 to 50. Southwest wind 5 to 10 mph.
Friday: Showers likely. Highs 60 to 65. Southwest wind 5 to 10 mph.
Comments (0)
May
17
Coupler
2002 Sears Kenmore Washer made by Whirlpool(model#11024832200): Not spinning at all, I found the motor coupler, Part#285753, broken that connects it to the gearcase(transmission). Always make sure you can turn the gearcase shaft both ways, use a wrench in needed, If it won’t turn, then the gearcase is locked-up and will need to be replaced as well.
Drive motor to transmission coupling, replaces all previous styles and versions. For direct-drive washers with no belt.
2855
Issued: May 17, 2005 20:54:46 PDT
Tonight: Rain. Lows around 50. Southeast wind 10 to 20 mph.
Wednesday: Occasional showers in the morning…then occasional showers and a slight chance of thunderstorms in the afternoon. Highs 60 to 65. South wind 15 to 25 mph.
Comments (0)
