Archive for May, 2005
Air Diffuser
Posted by: | Comments2001 Sears Kenmore Side by Side Refrigerator made by Whirlpool(model#10653254201): Not Cooling in the refrigerator section, I put my hand back in the top left corner to see if any air was coming out of the diffuser,none was at all. Part#2216112. I installed the new one, worked great.
Air Diffuser Assembly
Have a good evening!
South Willamette Valley
Issued: May 16, 2005 21:15:41 PDT
Tonight: Mostly cloudy. A chance of showers in the evening…then isolated showers after midnight. Lows around 45. Southwest wind 5 to 10 mph becoming southeast after midnight.
Tuesday: A chance of rain in the morning…then rain likely in the afternoon. Highs around 60. Southeast wind 5 to 15 mph.
Maytag Evaporator Fan Motor
Posted by: | Comments2003 Maytag Freezer on Top Refrigerator(model#MTF2156GEW). The problem was that the refrigerator section was starting to get warm, I found the Freezer(Evaporator) fan motor was not turning at all. It was getting the proper 120 voltage to it. I ohmed it out, there was no continuity through it.
Part#61005935
Motor, evaporator fan (w/wire lead)
Have a good evening and weekend!
Issued: May 14, 2005 14:50:55 PDT
Tonight: A chance of showers in the evening…then rain tonight. Lows around 55. Southwest wind 10 mph.
Sunday: Rain. Highs around 65. South wind 10 mph.
Kitchen Aid Dishwasher Thermal Fuse
Posted by: | Comments2004 Kitchen Aid Dishwasher(model#KUDS01ILWH3): No lights coming on , nothing working at all. I found the Thermal Fuse out, no continuity through it at all. Part#8193762. This part going out is due to excessive hot water. I advised the consumer to turn down the hot water heater in his home. It was very hot coming out of the tap.
Fuse kit with wire harness and instructions
Issued: May 12, 2005 20:43:54 PDT
Tonight: Mostly clear in the evening then becoming partly cloudy. Lows 45 to 50 light wind..
Friday: Mostly cloudy. Highs around 70. West wind 5 to 10 mph.
Tub seal & bearing kit
Posted by: | CommentsFrigidaire and Sears Kenmore(model# starting with 417) made by Frigidaire.
Thanks to jnicosia and everyone for helping on this repair.
You can read more on this in the Forums section. Link> Drum Gasket and Rear Shell Bearings.
Coin Trap
Posted by: | CommentsSears Kenmore Front Load Washer made by Frigidaire(model#41741052000): Leaking water under the water pump, Found the Coin Trap that connects before the water pump, had a hole in it. Part#131784700.
Coin Trap
Issued: May 09, 2005 21:17:10 PDT
Tonight: Rain. Lows around 45. South wind 5 to 10 mph.
Tuesday: Rain in the morning…then showers in the afternoon. Highs around 60. Southwest wind 5 to 15 mph.
Maytag Front Load Neptune Washer
Posted by: | Comments2000 Maytag Front Load Neptune Washer(model#MAH7500AWW): Not spinning, Found the Motor controller board malfunctioning.
The controller board has been upgraded and includes a motor in the kit, Part#12002039.
Motor/control conversion kit, Neptune washer
Have a evening and weekend!
Issued: May 07, 2005 21:16:48 PDT
Tonight: A chance of rain in the evening…then rain at times after midnight. Lows 50 to 55 light wind..
Sunday: Rain likely in the morning…then showers likely and a slight chance of thunderstorms in the afternoon. Highs around 60 light wind.
New Style Kenmore Front Load Washer
Posted by: | Comments2005 Sears Kenmore Front Load Washer made by Frigidaire(model#41744052400): I have seen 2 of these new re-designed models this year having a sound issue when the washer is just off, not in use. What you will hear is like a humming or whistling sound coming from the front control panel when the washer is completely off at all times.
It will need a new control panel assembly, if you call Sears for a tech. to come out to your home, they will order and install it free of charge under the 1st year parts and labor warranty.
Part#134484016
Point & Click Appliance Repair has a link to the Control Panel Assembly
