Archive for June, 2005
Maytag Glasstop Burner Element
Posted by: | Comments2002 Maytag Free Standing Range(Model#MER6750AAW): The left front burner element was not coming on at all, found a break in the element coil. To Replace these you have to raise up the glasstop assembly, then they can be accessed.
Part#74005476
Surface element w/limiter (6″)
(The manufacturer has replaced part number 74005476 with this item, part number 12002141.)
Have a good Flag Day!
South Willamette Valley
Issued: June 14, 2005 03:53:01 PDT
Today: Mostly cloudy. A chance of sprinkles in the morning. Highs 65 to 70. Light wind becoming north 5 to 15 mph in the afternoon.
Tonight: Mostly cloudy. Lows 45 to 50. North wind 5 to 10 mph becoming light after midnight.
Operating Thermostat
Posted by: | CommentsOperating Thermostats are key to the heating cycles during the dryer run times. It cuts off the element when it reaches the set temperature labaled on the cycling thermostat.
Dryer cycling thermostat with internal bias heater, L155-25
Have a good weekend!
Issued: June 10, 2005 15:49:57 PDT
Tonight: Mostly cloudy with a chance of showers. Lows around 50. Northwest wind 10 mph.
Saturday: Mostly cloudy with a chance of showers. Highs 60 to 65. Northwest wind 10 mph.
Frigidaire Side by Side Control housing kit
Posted by: | Comments2003 Frigidaire (SIDE BY SIDE)
Model #FRS26R4AW7
Freezing everything in the refrigerator side.
It will need this new kit.
Part#240521103
Control housing kit
Whirlpool Dryer Rollers & Idler Pully
Posted by: | CommentsA common Whirlpool and Kenmore Dryer that has the 2 drum rollers, The lint filter is on the top right side of these dryers.
Part#3397588
Rear drum support roller kit (2) in kit, Whirlpool-Kenmore, and others
A Idler Pulley, this also replaces the Idler Slide style that some of the newer models have.
Part#3394332
Belt tension pulley, fits virtually all whirlpool-made dryers
Whirlpool, Sears Kenmore, Roper, Estate Dryer Tune-Up Kits
Part#4392065
2 Roller Dryer Repair Kit for Whirlpool, Kenmore, Roper Dryers; rollers, belt and idler pulley, for 29″ wide Dryers built 1965 and later
Another common Whirlpool and Kenmore Dryer that has 4 Rollers, The Lint filter is just inside of the door.
Part#4392067
4 Roller Dryer Repair Kit for Whirlpool, Kenmore Dryers; includes drum belt, 4 rollers and idler pulley, For 27″ wide dryers built 1965 and later and Thin Twins
Dryer repair manual for Whirlpool – Sears – Kenmore – Kitchen Aid – Roper – Estate large capacity dryers. Gas or electric. Revision H (copyright 1998)
GE Defrost Heater
Posted by: | Comments2002 GE Side by Side Refrigerator(Model#GSS20IEMBCC): Not cooling well at all, Found the back wall evaporator and panel in freezer all frosted up, the glass defrost heating element was burned out, no continuity through it at all. The CalRod defrost heaters very rarely go bad and burn out, most of the CalRod defrost heaters are solid black in color.
Part#WR51X10053
Defrost heater and bracket assembly
Have a good evening!
Issued: June 06, 2005 22:42:56 PDT
Tonight: Showers…then scattered showers after midnight. Lows 45 to 50 light wind..
Tuesday: A chance of showers in the morning…then showers likely and a slight chance of thunderstorms in the afternoon. Highs 60 to 65. South wind 5 to 10 mph shifting to the west in the afternoon.
Amana Water Valve
Posted by: | Comments1997 Amana Side by Side Refrigerator(Model#SXD22S2W)(Manufacturer#P1303503WW): No water coming out from the front water dispenser when the lever is pushed for water, Found the water valve coil shorted that controls the water to the dispenser, the ice maker was getting water from the other coil fine.
Part#D7742204
Icemaker water inlet valve for water and ice through the door, with 2 coils & outlets, and multi-position solenoids. Requires hose type water line connection.
Have a good evening and weekend!
Issued: June 03, 2005 21:31:48 PDT
Tonight: Partly cloudy becoming mostly cloudy late. Lows around 45. North wind 5 to 10 mph becoming light wind.
Saturday: Mostly cloudy in the morning then becoming partly sunny. Highs 65 to 70. North wind 5 to 10 mph.
Evaporator/Freezer Fan Motor
Posted by: | Comments2004 Frigidaire Top Freezer Refrigerator(Model#FRT18B4AWA): Not cooling, Found the evaporator/freezer fan motor shorted out. When you open the freezer door and you should hear the freezer fan turning fast, blowing alot of cold air when the compressor is running, Some of the newer freezer fans are variable speed, mostly on the newer GE Refrigerators.
Part#240369701
Motor, freezer fan
Issued: June 02, 2005 21:34:38 PDT
Tonight: Mostly cloudy. Lows around 45 light wind..
Friday: Mostly cloudy in the morning then becoming partly sunny. Highs around 70. Light wind becoming northwest 10 mph in the afternoon.
