Archive for July, 2005
Water Pump
Posted by: | Comments1996 Sears Kenmore washer made by Whirlpool(Model#11092596100): Leaking water from the front of the washer, found a leak in the water pump.
Part#3363394
Drain pump for belt-less direct-drive washer, one large port, one small port
Have a good evening!
South Willamette Valley
Issued: July 31, 2005 21:18:08 PDT
Tonight: Clear in the evening…then partly cloudy late. Lows around 55. West wind 10 to 15 mph.
Monday: Mostly cloudy in the morning…then partly sunny. Not as warm. Highs around 80. Northwest wind 5 to 15 mph.
Dishwasher Door Gasket
Posted by: | Comments2005 Whirlpool Dishwasher(Model#GU2500XTPQ3): Small leak from the bottom of the tub, found the door gasket not formed correctly in one spot. Its easy to install, it just pushes in place.
Part#8268888
Door gasket
Have a good weekend!
Issued: July 30, 2005 21:31:03 PDT
Tonight: Clear. Lows in the 50s. Northwest wind 5 to 10 mph.
Sunday: Sunny. Highs 90 to 95. Afternoon north wind 5 to 15 mph.
Ice Maker Thermostat(Bi-Metal)
Posted by: | Comments2003 Sears Kenmore Side by Side Refrigerator(Model#10653642300): Ice maker stops making ice at times, and is very slow to produce ice, Found the thermostat malfunctioning,
Part#627985
Thermostat kit (modular im)
Recommended Related Item: Thermal Mastic, RCC 632968
Issued: July 28, 2005 21:31:38 PDT
Tonight: Clear. Lows in the low to mid 50s. North wind 10 to 15 mph.
Friday: Sunny. Highs 85 to 90. Light wind becoming north 10 mph in the afternoon.
Air Duct Assembly
Posted by: | Comments1998 G.E. Dryer(Model#DNSR473EV0WW): Making a bad noise and the filter air duct assembly is cracked and broken.
Part#WE14M92
Front air duct assembly with lower drum seal, duct seal & sensor bars
Issued: July 27, 2005 21:29:08 PDT
Tonight: Clear. Lows in the mid to upper 50s. Northwest wind 15 mph shifting becoming light after midnight.
Thursday: Patchy morning clouds otherwise sunny. Highs 85 to 90. Northwest wind 10 to 15 mph.
Oven Sensor & Control Board
Posted by: | Comments2000 Sears Kenmore Range made by Whirlpool(Model#66595802000): Error Code F3-E0 showing in the control panel display, The control board grounded to the broil element, causing the broil element to always be on, thus causing the oven sensor to overheat and shut down showing F3-E0 in display.
Oven Sensor
Part#8273340
Electronic control board
Part#8523665
Issued: July 23, 2005 22:43:09 PDT
Tonight: Clear. Lows around 50. North wind 5 to 10 mph decreasing.
Sunday: Sunny. Highs 80 to 85. North wind 10 to 15 mph.
Defrost Control
Posted by: | Comments2001 Maytag Side by Side Refrigerator(Model#MSD2758DRW): Not Cooling well in the freezer section, Found frost build up on evaporator coil, Adaptive defrost control board was bad, Defrosted Evaporator coil, installed new Adaptive Defrost control board.
Part#61005988
Issued: July 22, 2005 21:44:26 PDT
Tonight: Mostly clear. Cooler. Lows 50 to 55. North wind 5 to 10 mph.
Saturday: Mostly sunny. Highs 80 to 85. Light wind becoming north 10 to 15 mph in the afternoon.
Dishwasher Fuse
Posted by: | Comments1998 KitchenAid Dishwasher(Model#KUDR24SEWH2): Not working at all, no lights coming on either, Found the Thermal Fuse bad.
Part#675796
Fuse assembly with wire harness
Issued: July 21, 2005 21:26:06 PDT
Tonight: Mostly cloudy with scattered showers and isolated thunderstorms. Lows around 60. Southwest wind 5 to 10 mph.
Friday: Mostly cloudy with a slight chance of showers in the morning…then mostly sunny in the afternoon. Highs 80 to 85. Southwest wind 5 to 10 mph.
