Archive for August, 2005
Aug
13
Defrost Thermostat(Bi-Metal)
2003 Whirlpool Top-Mount Refrigerator(Freezer on Top)(Model#ET8GTKXKQ00): Back of the freezer panel was all frosted up, not cooling well in refrigerator section. Ohmed out the defrost thermostat thats mounted on the left upper side of the evaporator coil behind that freezer panel, No continuity when that was still in the frost, before i defrosted the whole coil.
Part#2188824
Defrost thermostat, clip-on
1055108
Have a good evening!
South Willamette Valley
Issued: August 13, 2005 14:08:28 PDT
Tonight: Clear. Lows 55 to 60. Northeast wind 5 to 15 mph.
Sunday: Sunny. Highs around 95. North wind 5 to 10 mph.
Categories : The Daily Diary 2
Comments (0)
Aug
12
Lint Screen
2005 Sears Kenmore Dryer made by Whirlpool(Model#11064742400): The Lint Screen handle has broken from the screen assembly.
Part#8557882
Dryer lint filter, white handled lint screen for most large and extra capacity dryers, measures 19 3/8″ x 7 1/8″.
1038742
Have a good evening and weekend!
Issued: August 12, 2005 21:33:24 PDT
Tonight: Clear. Lows around 55. North wind 5 to 10 mph.
Saturday: Sunny. Highs 90 to 95. Northeast wind 10 to 15 mph.
Comments (0)
Aug
11
Ice Maker Replacement
2005 Sears Kenmore Freezer on Bottom Refrigerator made by Amana(Model#59675939400): Ice maker not working properly, installed a new one.
Part#D7824706Q
Icemaker replacement, modular style, no cover, wire harness or hardware
915772
Issued: August 11, 2005 21:30:01 PDT
Tonight: Clear. Lows 50 to 55. North wind 5 to 10 mph.
Friday: Mostly sunny. Highs around 85. North wind 5 to 10 mph.
Comments (0)
Aug
07
Washing Machine Timer
1995 Sears Kenmore Washer made by Whirlpool(Model#11092480200): Timer not advancing at certain spots in the Regular cycle, found the timer contacts starting to wear out, would need a new timer.
Timer
Part#3946452
546881
Issued: August 07, 2005 21:25:22 PDT
Tonight: Clear. Lows 50 to 55. North wind 5 to 15 mph.
Monday: Sunny. Highs in the mid to upper 80s. North wind 5 to 10 mph.
Comments (0)
Aug
06
Motor and Heater Relay’s
2003 Kenmore Evenheat Dryer made by Whirlpool(Model#11063952102):
When you push the start button it starts, but when you release the button it stops, won’t stay on. Alot of the times the control board causes this, but this time the motor relay was out. I replaced the motor relay, the dryer kept running like its suppose to, but it would not heat, I ohmed the 2 left side smaller connections and found the heater relay with no continuity. So i replaced that relay, same Part#3405281.
Part#3405281
Motor/heat relay
528722
Issued: August 06, 2005 21:29:27 PDT
Tonight: Clear. Lows around 55. North wind 5 to 15 mph.
Sunday: Sunny. Highs 85 to 90. Light wind becoming north 10 to 15 mph in the afternoon.
Comments (0)
Aug
05
Water Valve
2005 Roper Washing Machine(Model#RAX4232PQ0): Water valve was cracked and leaking, possible shipping damage. No charge to install a new one, under the 1 year warranty.
Washing machine water inlet valve kit
868761
Issued: August 05, 2005 21:32:05 PDT
Saturday: Sunny. Highs around 90. North wind 5 to 15 mph.
Comments (0)
Aug
04
Dishwasher Pump Motor
2002 KitchenAid Dishwasher(Model#KUDS01DJSS1): Pump motor making a loud bearing noise, not draining the water out.
Part#661658
Drain pump assembly
916417
Issued: August 04, 2005 21:39:43 PDT
Friday: Mostly sunny. Highs 90 to 95. North wind 5 to 10 mph.
Comments (0)
