Archive for September, 2005
Kenmore Washer Motor
Posted by: | Comments2001 Sears Kenmore Washer made by Whirlpool(model#11022852100): The motor bearing had gone out, it was very loud when it was running.
I installed a new motor, consumer had a service contract, no charge.
The repair cost would have been at $339.00 total.
Part#3352287
Washing machine drive motor, 3 speed, 1725/1140/850, Amps- 9.8/8.5/8.8
Have a good evening!
South Willamette Valley
Issued: September 29, 2005 21:32:08 PDT
Tonight: Becoming cloudy. A chance of rain after midnight. Lows around 55. Southwest wind 5 to 10 mph.
Friday: Rain likely. Highs 65 to 70. Southwest wind 5 to 10 mph.
Maytag Clock Control Board
Posted by: | Comments2004 Maytag Range(Model#MER5775QAW): The clock display is not working, also the touchpad on the control does not work.
Found the clock/control board assembly shorted internally.
Part#74009221
Clock/overlay (wht)
Issued: September 28, 2005 21:29:52 PDT
Tonight: Clear. Lows around 45. West wind 5 to 10 mph.
Thursday: Mostly sunny in the morning…then partly sunny. Highs 75 to 80. Southwest wind 5 to 10 mph.
Auger Drum
Posted by: | Comments2004 Sears Kenmore side by side Refrigerator made by Whirlpool(model#10655512400): Not Dispensing any ice at all, Found the Auger Drum that sits in the front part of the ice bucket had broken, It turns with the auger itself, and has plastic impeller style blades on it.
Part#4388736
Ice bin auger drum
Have a good evening and weekend!
Issued: September 24, 2005 14:44:42 PDT
Tonight: Clear. Lows 35 to 40. North wind 10 mph.
Sunday: Mostly sunny. Highs around 75. North wind 5 to 15 mph.
Dual Water Inlet Valve
Posted by: | Comments1997 Sears Kenmore Side by Side made by Frigidaire(model#25357682790) : No water coming out from the front water dispenser, found the Dual water valve bad.
Part#218658000
Dual water inlet valve, water filter
Issued: September 20, 2005 21:12:14 PDT
Tonight: Mostly clear. Lows 40 to 45. North wind 5 to 15 mph.
Wednesday: Mostly sunny. Highs around 75. North wind 5 to 10 mph.
Dryer Gas Coils
Posted by: | Comments1999 Sears Kenmore Dryer made by Whirlpool(model#11076722695): The Ignitor starts to glow then shuts down before the gas comes on to ignite the burner, Found the gas coils bad.
Part#279834
Gas valve solenoid coil kit, 2 and 3 wire, new style
Have a good weekend!
Issued: September 17, 2005 21:21:28 PDT
Tonight: Partly cloudy. Patchy fog after midnight. Lows around 45 light wind..
Sunday: Partly sunny in the morning…then mostly sunny. Patchy fog in the morning. Highs around 75. Light wind becoming north 10 to 15 mph in the afternoon.
Kenmore Dryer Timer
Posted by: | CommentsSears Kenmore Dryer made by Whirlpool(110.68202794): Timer problems are not that common on most brands with mechanical timers, but can break or wear out like most other parts. Either the timer stops turning in the timed cycle, or does not turn the dryer off at all.
Part#3976582
Timer
GE Water Pump
Posted by: | Comments2005 GE Washer(Model#WDSR2080D0WW): Not draining the water after the wash and rinse cycles, Found the water pump bearing very noisey and not turning correctly. No charge to replace, still under the 1 year warranty.
Pump and Motor Assembly
P/N: WH23X10013
Issued: September 13, 2005 21:35:07 PDT
Tonight: Mostly clear. Lows 45 to 50. North wind 10 mph.
Wednesday: Mostly sunny. Highs in the mid and upper 70s. Northwest wind 10 mph.
