Archive for October, 2005
Oct
14
Front Load Washer Door Lock
2002 Sears Kenmore Front Load Washer made by Frigidaire(model#41742042100): The front door was locking in the spin cycle, but when you turned the washer off, it opened right away, there should be a 2 minute delay before you can open the door when the washer goes off. Its fairly easy to change this part, you take off the top and lower access panel, then remove the front screws and wire harness that mount it.
Part#131763200
Door lock and switch assembly
774920
Have a good weekend!
South Willamette Valley
Issued: October 14, 2005 21:39:18 PDT
Tonight: Rain. Lows 45 to 50. South wind 15 to 20 mph.
Saturday: Showers. Highs around 60. Southwest wind 10 to 20 mph.
Categories : The Daily Diary 2
Comments (0)
Oct
13
Clock/Oven Control Board
2001 Sears Kenmore Range made by Frigidaire (model#790468099902): Clock display showing a F1 error code, won’t reset. This happened while the consumer was not even using the Range. The Electronic Control Display assembly will need to be replaced.
Part#318019902
Electronic clock control assembly, black
781676
Have a good day and evening!
Issued: October 13, 2005 05:52:45 PDT
Today: Mostly cloudy. A chance of light rain or drizzle later this morning…then a slight chance of showers in the afternoon. Highs 60 to 65 light wind..
Tonight: Partly cloudy. Patchy fog after midnight. Lows 40 to 45. East wind 5 to 10 mph.
Comments (0)
Oct
06
2004 Whirlpool Duet Dryer (model#GEW9200LW1): The main cycle control knob was cracked, causing the switch not to turn properly into the correct settings. These knobs tend to be very reliable, its rare to see these just crack. Under the 1st year full warranty, no charge.
Part#8181859
Control Knob, Gray
906595
Have a good evening!
Issued: October 06, 2005 14:21:59 PDT
Tonight: Mostly cloudy with a chance of rain. Lows 45 to 50. Southwest wind 5 to 10 mph.
Friday: Mostly cloudy with a chance of showers. Highs 60 to 65. Southwest wind 5 to 10 mph becoming northwest in the afternoon.
Comments (0)
Oct
03
Sears Kenmore Washer Motor
1989 Sears Kenmore Washer made by Whirlpool(model#11082883100): Motor making a loud buzzing sound when its in the wash cycle, found the motor switch was bad. The motor has to be replaced.
Part#389248
Washing machine drive motor, 2 speed
769
Issued: October 03, 2005 21:34:08 PDT
Tonight: Mostly cloudy with isolated showers ending. Areas of fog forming. Lows near 40 light wind..
Tuesday: Mostly cloudy with areas of morning fog…becoming partly sunny. Highs 60 to 65 light wind.
Comments (0)
