Archive for November, 2005
Cooking Thermometer
Posted by: | CommentsJust in time for the holidays when stoves, ranges, ansd ovens get a good workout.
Polder Cooking Thermometer with Timer and Clock
Three functions in one. Thermometer: large LCD read out displays the temperature of food during cooking (14 – 392 Fahrenheit). Presettable HI/LOW and ‘inside the range’ temperature alert. Timer: 24 hour count down and count-up. Clock: Real-time clock. Stainless steel probe measures 39-inches. Temperature chart and battery included.
Kenmore Timer
Posted by: | CommentsSears Kenmore Washer made by Whirlpool(model#11022722101): The timer was stalling in the wash cycle, found burned out contacts in that part of the timer cycle.
The timers are fairly easy to replace, Jeff from our forums has a great how to section on his website
Part#3955193
Timer
(The manufacturer has replaced part number 3955193 with this item, part number 661649.)
Have a good weekend!
Range Bake Element
Posted by: | CommentsSears Kenmore Electric Range made by Whirlpool (model#665.95002101): Oven is not heating when the bake cycle is on, I always make sure the range is receiving 240 volts at the range terminal block, a volt/ohm meter is a necessity. If that checks ok, then I check the the bake element for continuity with the ohm meter, make sure the power to the range is off first before testing the bake element for continuity.
There was no continuity in the bake element, when i checked it.
Part#8053713
Oven bake element assembly with push-on terminals
Have a good evening!
South Willamette Valley
Issued: November 07, 2005 14:43:40 PST
Tonight: Mostly cloudy in the evening…then partly cloudy. A chance of showers. A slight chance of a thunderstorm this evening. Colder. Lows 30 to 35 light wind..
Tuesday: Partly cloudy with a slight chance of rain. Highs around 50. South wind 5 to 10 mph.
Refrigerator Door Gasket
Posted by: | Comments2004 Sears Kenmore Top Mount(Freezer on Top) Refrigerator made by Frigidaire(model#25363712302): The Refrigerator door gasket is not sealing properly, found a torn spot in it. These gaskets seem to hold up pretty good, but every once in awhile you may see a loose, torn, or crimped door gasket.
They used to have screws that held them in place, but now most are the push-in type, which is a great time saver!
Part#240542106
Gasket-refr door
Issued: November 04, 2005 04:20:26 PST
Today: Showers. Highs around 50. South wind 15 to 20 mph.
Tonight: Showers likely. Lows 40 to 45. Southwest wind 5 to 15 mph.
Thermometer & Hygrometer
Posted by: | CommentsTemperature & Humidity
I have owned one of these for many years, I couldn’t be happier, it works great!
Bemis calibrated digital temperature & humidity gauge. Table stand or wall mount. Battery included. Humidity range 10% – 99%. Temperature range 14 to 122 degrees Fahrenheit (-10 – 50 degrees Celsius). Put one in the basement and one near the bedrooms.
Issued: November 01, 2005 21:26:06 PST
Tonight: Showers likely. Colder. Lows around 40. Southwest wind 10 to 15 mph decreasing.
Wednesday: Showers likely. Highs around 50. Southwest wind 5 to 10 mph.
