Archive for December, 2005
Dec
30
Happy New Year
Here is a forum question and answer on this:
Maytag side/side model#:MSD2756DEB
About a month ago I started noticing some water leaking underneath my freezer door and about the same time I noticed that my fridge and freezer were not cooling as efficiently as before. Deciding to plunge into repairs, I took apart the back panel and vacuumed up everything I could see that was in need of it. Still, no better on the cooling.
After surfing this site I got the idea to check out back portion of the freezer. Sure enough, the back cover had about an inch of ice that I could see from the just looking in by the door. I shut off the fridge, and started warming up the firdge. Used a hair dryer to defrost the cover, and once I got into the back cover I found the whole coil frozen over. From top to bottom. I defrosted the whole thing. Took about 2 hours and looked around, but really couldn’t see anything major (leaks or broken wires). Put everything back together, and plugged in the fridge and everything works great.
Now its been about 3 weeks and I am seeing the icey build up on the panel in the back of the freezer again. I think I am going to replace the heater/thermostat assembly tomorrow. (maytag part # 61006199)
1025806
90% of the time on these Maytag’s the Defrost Board Part#61005988 will be the problem when the evaporator coil is all frosted up like that.
To be sure, I always do a continuity check with a ohm meter on the defrost thermostat and the heater assembly. You can get a very cheap ohm meter at Radio Shack, and test these with the power off to the refrigerator.
Here is a blog entry i did back in July, this is the same part you will need if your defrost thermostat and heater test good. You can even order that defrost board from my blog entry by clicking on the picture or the part#.
948430
This thread talks all about it, and explains how to change it.
http://www.applianceblog.com/mainfor…read.php?t=223
Categories : Holidays
Comments (0)
Dec
28
GE Motherboard
2003 GE Side by Side Refrigerator (model#GSS25JEPABB): The main control board (aka the motherboard) has a great deal of functionality to it. Its the brain that controls the refrigerator fan motors, defrost cycle, temperature, sensors. I have seen these boards go bad mainly when it has defrost system problems or cooling problems.
The board is located on the very back outside wall of the refrigerator that has a metal shield thats covers it. Its easy to change out, just make sure the refrigerator is unplugged first. The connectors are the same, just unsnap the ones from the old board, making sure you either memorize where they go or writing it down on some paper, then install the new board and reconnect the wire connectors.
Part#WR55X10174
Main control board
1042206
Have a good evening!
Area Forecast For: South Willamette Valley
Issued: December 28, 2005 21:09:12 PST
Tonight: Showers likely. Lows around 40. Southwest wind 10 mph.
Thursday: Showers likely in the morning…then a chance of showers in the afternoon. Highs 45 to 50. Southeast wind 5 to 10 mph.
Categories : Refrigerators
Comments (0)
Dec
26
On Sale This Week
Garbage disposers seem to work very good over the years. Yes they can jam up at times if something like a seeds or bones gets stuck in between the blades. But they can be easily removed by using the turn key, thats always supplied with new units, and carefully taking the item out, always make sure the power supply to the garbage disposer is off before doing this.
All Maytag garbage disposers are 10% off. Get yours today!
Comments (0)
Dec
25
Electonic Control Board
KitchenAid Slide-In Range (model#KESC307GBS1): Yesterday the electronic control clock assembly was not working properly, the relay on the control board that makes the bake element come on was faulty, no power was going to the bake element, and it should of had 240 volts to it.
Part#3191106
Electronic clock control
504146
Hope everyone had a good Christmas!
Issued: December 25, 2005 21:22:27 PST
Tonight: Rain. Lows around 45. Southeast wind 10 to 15 mph.
Monday: Showers likely. Windy. Highs around 50. South wind 15 to 25 mph.
Categories : Ranges
Comments (0)
Dec
22
Testing a refrigerator inlet water valve
Here is a good question that was posted in our Forums
I have a 1996 Whirlpool model # ET22DQLDW01. It has an ice/water dispenser on the front door. The water dispenser has suddenly quit operating. I can hear a hum when I press in on the dispenser lever, but not even the slightest drip of water. It appears that the ice maker is still operating ok.
I posted the easy way to test it:
Sounds like the inlet water valve went out. Its in the back of the refrigerator where your water supply line hooks-up to it.
If you wanted to do-it-yourself you could un-mount it and take off the larger of the 2 plastic water lines and get a small bucket, and have someone press the dispenser, if nothing comes out, then its your inlet water valve for sure.
Here is the water valve for your model:
Icemaker and water dispenser water inlet valve kit
3307
Comments (0)
Dec
21
KitchenAid Dishwasher Pump/Motor
KitchenAid Dishwasher (model#KUDM24SEWH4): Not cleaning the dishes well, water seemed to never really clean itself out. Left kind of like left a soapy dirty film on the dishes when the cycle was done. Found the pump/motor assembly broken.
Part#9743202
Pump and motor assembly complete with self-cleaning.
1065408
Issued: December 21, 2005 21:33:27 PST
Tonight: Rain at times. Lows around 45. Southeast wind 10 to 15 mph.
Thursday: Rain. Highs 50 to 55. South wind 15 to 25 mph.
Categories : Dishwashers
Comments (0)
Dec
18
Front Load Whirlpool Duet & Kenmore HE3
Repair Service Manuals are the best way to do-it-yourself on all appliances.
This Front Load one here covers the basics with photo’s of how to remove and replace parts the proper way.
Whirlpool Duet & Kenmore HE3 front load washer repair manual
1025824
Have a Good Day and Weekend!
Issued: December 18, 2005 07:58:28 PST
Today: Mostly cloudy. A chance of rain. A slight chance of local light freezing rain in the morning. Highs around 40. North wind 5 to 15 mph.
Tonight: Rain likely. Lows around 35. Southeast wind 5 to 10 mph.
Categories : Washers
Comments (0)
