Archive for December, 2005
Cold Control Operating Thermostat
Posted by: | CommentsFrigidaire side by side Refrigerator (model#FRS26W2AQ1): Getting to cold and freezing stuff in the refrigerator section. It will need the updated control housing kit.
Part#5303918283
Control housing kit
(The manufacturer has replaced part number 240440701 with this item, part number 5303918283.)
Have a good evening!
SOUTH WILLAMETTE VALLEY-
INCLUDING THE CITIES OF…EUGENE…CORVALLIS…ALBANY
920 AM PST WED DEC 14 2005
…AIR STAGNATION ADVISORY NOW IN EFFECT UNTIL 10 AM PST SUNDAY
FOR THE SOUTH WILLAMETTE VALLEY..
THE AIR STAGNATION ADVISORY IS NOW IN EFFECT UNTIL 10 AM PST
SUNDAY.
STRONG HIGH PRESSURE ALOFT WILL CONTINUE THROUGH THE WEEKEND.
THIS WEATHER PATTERN WILL RESULT IN LIGHT WINDS AND LITTLE MIXING
OF THE AIR…WHICH WILL CAUSE POLLUTANTS TO BECOME TRAPPED NEAR
THE SURFACE.
Area Forecast For: South Willamette Valley
Issued: December 14, 2005 09:51:14 PST
Today: Considerable fog and low clouds. Becoming partly sunny in the afternoon. Patchy freezing fog through late morning. Highs in the mid 30s to lower 40s. North wind to 10 mph.
Tonight: Mostly clear in the evening…then widespread fog and low clouds. Patchy freezing fog. Lows 25 to 30 light wind.
Gourmet Cooking and Canning
Posted by: | CommentsOn Sale this week is a good surface burner element for gourmet cooking and canning during this holiday season.
Gourmet Cooking and Canning Electric Range Surface Element
8-inch – Heavy-duty, 2600-watt, five-turn, 8-inch surface plug-in element is designed to withstand prolonged high temperature cooking. The extra-high frame protects the range surface and burner pan from excessive heat and discoloration. Fits most brands of electric ranges except General Electric.
Issued: December 12, 2005 17:03:30 PST
Tonight: Mostly cloudy. Areas of fog through the night. Lows around 30 light wind..
Tuesday: Mostly cloudy in the morning…then partly sunny. Areas of fog in the morning. Highs around 40. North wind 10 mph.
Amana Glow Bar
Posted by: | Comments1992 Amana Range(model#AGS745W–manufacturer#P1113904S): The oven would not heat up, the bake glow bar ignitor would start glowing slowly, but was worn out, with normal use, and it wouldn’t send a signal to the safty valve to let the gas come out to the bake burner.
The oven ignitor will need to be replaced.
Part#0309159
Common long ceramic oven and broiler igniter
Have a good evening and weekend!
Issued: December 09, 2005 09:49:36 PST
Today: Mostly sunny. Patchy freezing fog in the morning. Highs 40 to 45 light wind..
Tonight: Clear in the evening…then partly cloudy. Areas of freezing fog. Lows 25 to 30 light wind.
On Sale this Week
Posted by: | CommentsThe number one cause of all dryer problems is poor ventilation. Clothes taking 90 mins. to 2 hours are longer to dry, is a sure sign of poor air flow through the dryer and out the exhaust vent.
Many homes built today have very long exhaust vent runs to get to the outside to vent, those need to be cleaned at least twice a year.
You can pull the dryer away from the wall to make sure the dryer vent inside the unit is not clogged as well. The air should be blowing out very fast.
Here are two items on sale this week, that will help clean your dryer exhaust vent.
2 different lengths:
Vent Brush For Cleaning 4-inch Round Dryer Vent 10 foot
The Larger Size
Vent Brush For Cleaning 4-inch Round Dryer Vent 20 foot
Issued: December 06, 2005 15:04:00 PST
Tonight: Mostly cloudy with a slight chance of rain. Areas of fog. Lows around 35. Northeast wind 5 to 15 mph.
Wednesday: Rain likely. Highs around 40. Northeast wind 10 to 15 mph.
Water inlet valve
Posted by: | CommentsThis is a common water inlet valve for the Sears Kenmore made by Whirlpool(model# starting with 106), and the Whirlpool/KitchenAid brands.
Always match your model# with the parts guide when you look it up as they do make serveral variations of this valve.
Icemaker and water dispenser water inlet valve kit
Whirlpool Range
Posted by: | Comments2004 Whirlpool Range (Model#RF388LXKP0): The control board/clock was not working at all. Checked for 120 volts to the control board, that was ok. The control board shorted out. Installed new one, worked great.
Part#8522527
Cntrl-elec, (White in color)
(The manufacturer has replaced part number 8522527 with this item, part number 8523332.)
Issued: December 01, 2005 14:45:29 PST
Tonight: Showers. Lows around 35. South wind 10 to 15 mph.
Friday: Showers. Highs 40 to 45. Southwest wind 10 to 20 mph.
