• Home
  • Appliance Repair Forums
  • Appliance Parts
  • Appliance Market Place
Subscribe to Appliance Blog – Appliance Repair Blog Forums
Get the latest updates delivered via email
Appliance Blog | Promote Your Page Too
Follow ApplianceBlog on Twitter
Archive for September, 2006
Sep
25
Whirlpool Dishwasher Pump Impeller
Whirlpool Dishwasher(Model#DU910PFGB0): Making loud noise in the wash and drain cycles.
I found all kinds of glass and fruit seeds down in the pump impeller assembly, and the impeller was broken due to all that as well.
Installed new pump impeller kit, worked great.
Dishwasher drain & wash impeller kit with motor shaft seal
830831
Categories : Dishwashers
Comments (0)
Sep
18
KitchenAid Dishwasher Thermal Fuse
2003 KitchenAid Dishwasher(Model#KUDS01FKSS01): The control panel display lights were all dead, nothing would come on. I turned off the house breaker to the dishwasher then opened up the control panel by taking off all the inner door screws, that will also release the front outer door panel.
Then I used my volt/ohm meter to ohm out the thermal fuse that’s attached to the control board to check for continuity. There was no continuity, so I replaced the thermal fuse assembly with the wiring that was included with it, thats a must, and it worked great.
Part#8193762
Fuse kit with wire harness and instructions
959376
Comments (0)
Sep
14
Ice Maker Water Inlet Valve
1999 Sears Kenmore Side by Side (Model#106.58582892)(Made by Whirlpool):
The ice maker had stopped making ice, but the water dispenser in the front was working fine. I ohmed out the ice maker solenoid on the water inlet valve, and it showed continuity, then i took off the electrical connector to the ice maker side of the water inlet valve solenoid and put my volt meter leads in it, and then cycled the ice maker. When the ice maker called for water, my volt meter went to 120 volts, so that told me that even though the solenoid showed it had continuity, it was still bad, it was just stuck closed.
I replaced the water inlet valve assembly and it worked good.
Water Inlet Valve
Part#4389177
949403
Categories : Refrigerators
Comments (0)
Sep
08
Kenmore Front Load Washer
2001 Kenmore Front Load Washer (Model#417.41042000 made by Frigidaire)
The problem the customer was having was the tub wouldn’t move at all in the wash or spin cycle.
I found the motor controller board was bad.
Part#131770700
Spin control board assembly
1021692
Categories : Washers
Comments (0)
Sep
01
Maytag Gemini Range Repair Manual
Here is a photo of the Maytag Gemini Double Oven Free Standing Range.
These have been fairly reliable, but I have seen some clock/electronic control board failure, but not many.
You can join our Maytag/Magic Chef/Jenn-Air Appliance Repair Talk Forum
You can order the Repair Manual by clicking the link or the picture.
824600
Have a Good Labor Day Weekend!
Its going to be a hot one here this weekend!
Area Forecast For: South Willamette Valley
Issued: September 01, 2006 03:36:48 PDT
Today: Sunny…warmer. Highs 90 to 95. North wind 5 to 10 mph. Gusts to 20 mph in the morning.
Tonight: Clear. Lows 50 to 55. Northwest wind 5 to 10 mph shifting to the south after midnight.
Categories : Maytag - Admiral - Magic Chef - Jenn Air
Comments (0)
Login
To ask appliance repair questions, please register at our forums: Appliance Repair Forums
Search Our Blog
Categories
  • Accessories (8)
  • Air Conditioners-Window/Wall (5)
  • Amana – Speed Queen – Caloric (7)
  • Appliance Blog Forum Links (68)
  • Dishwashers (34)
  • Dryers (44)
  • Entertainment News (1)
  • Frigidaire, Tappan, Gibson, White Westinghouse, Kenmore models 417 & 253 Appliance Repair Manuals (13)
  • GE – Hotpoint – RCA (9)
  • General Appliance Talk (42)
  • Holidays (13)
  • Maytag – Admiral – Magic Chef – Jenn Air (28)
  • Ranges (33)
  • Recalls (12)
  • Refrigerators (62)
  • Repair Manuals (1)
  • Shop New Appliances (1)
  • The Daily Diary (138)
  • The Daily Diary 2 (129)
  • Uncategorized (4)
  • Washers (47)
  • Weather (2)
  • Whirlpool – Sears Kenmore – KitchenAid (12)
Recent Comments
  • Jake on Washing machine stainless steel fill hoses
  • teachmemetric on Washing machine stainless steel fill hoses
  • adamwarlock on Overload/Relay
  • Jerry on Maytag Recalls Dishwashers Due to Fire Hazard
  • VickiSue on Sears Kenmore Washer Lid Switch
  • Curt on Sears Kenmore Washer Lid Switch
  • jkmarshall on Maytag Refrigerator Adaptive Defrost Board
  • jdesmarteau on Maytag Dryer Thermal Fuse
Tags
Adaptive Defrost Board air conditioner bearing Christmas cleaner cleaning clock condenser cooktop coupling Crosley defrost thermostat Dishwasher drain pump dryer fan Frigidaire GE heating element Hotpoint ice maker Kenmore lid switch Magic Chef maintenance Maytag meter motor oven oven control board oven igniter range Recall refrigerator seal Sears Sears Kenmore start device relay thanksgiving thermal fuse thermometer washer water filters water pump Whirlpool
Archives
  • May 2013 (1)
  • February 2013 (1)
  • December 2012 (1)
  • November 2012 (1)
  • September 2012 (1)
  • August 2012 (1)
  • July 2012 (1)
  • June 2012 (3)
  • May 2012 (2)
  • April 2012 (1)
  • March 2012 (1)
  • February 2012 (1)
  • December 2011 (2)
  • November 2011 (2)
  • September 2011 (1)
  • August 2011 (1)
  • July 2011 (1)
  • June 2011 (1)
  • May 2011 (1)
  • April 2011 (1)
  • March 2011 (1)
  • February 2011 (2)
  • January 2011 (2)
  • December 2010 (2)
  • November 2010 (4)
  • October 2010 (2)
  • September 2010 (1)
  • August 2010 (1)
  • July 2010 (1)
  • June 2010 (2)
  • May 2010 (1)
  • April 2010 (1)
  • March 2010 (1)
  • February 2010 (1)
  • January 2010 (1)
  • December 2009 (3)
  • November 2009 (3)
  • October 2009 (1)
  • September 2009 (2)
  • August 2009 (2)
  • July 2009 (3)
  • June 2009 (2)
  • May 2009 (2)
  • April 2009 (3)
  • March 2009 (2)
  • February 2009 (3)
  • January 2009 (3)
  • December 2008 (3)
  • November 2008 (6)
  • October 2008 (11)
  • September 2008 (8)
  • August 2008 (7)
  • July 2008 (19)
  • June 2008 (17)
  • May 2008 (20)
  • April 2008 (16)
  • March 2008 (6)
  • February 2008 (2)
  • January 2008 (1)
  • December 2007 (2)
  • November 2007 (1)
  • October 2007 (2)
  • September 2007 (1)
  • August 2007 (1)
  • July 2007 (1)
  • May 2007 (2)
  • April 2007 (3)
  • March 2007 (4)
  • February 2007 (4)
  • January 2007 (12)
  • December 2006 (11)
  • November 2006 (11)
  • October 2006 (11)
  • September 2006 (5)
  • August 2006 (3)
  • July 2006 (3)
  • June 2006 (3)
  • May 2006 (8)
  • April 2006 (8)
  • March 2006 (10)
  • February 2006 (9)
  • January 2006 (10)
  • December 2005 (13)
  • November 2005 (12)
  • October 2005 (11)
  • September 2005 (13)
  • August 2005 (14)
  • July 2005 (15)
  • June 2005 (14)
  • May 2005 (17)
  • April 2005 (19)
  • March 2005 (21)
  • February 2005 (22)
  • January 2005 (29)
  • December 2004 (35)
  • November 2004 (40)
  • October 2004 (31)
  • September 2004 (31)
  • August 2004 (29)
Copyright © 2013 All Rights Reserved
Flexx Theme by iThemes
Powered by WordPress
