Archive for October, 2006
I don’t see that many of my customers that have this model, but if you do have this model we want to hear from you. You can post a comment in this Appliance Blog post.
You can order the Repair Manual by clicking the link or the picture.
Maytag Styleline Electric Range Repair Manual.
421639
Oct
12
Maytag 30″ Wall Oven Repair Manual
Good Morning,
I want to finish the repair manual archive vault that was started in March 2006.
Here is the repair manual for the Maytag 30″ wall oven.
421568
Oct
11
Thrust Bearing Kit
1998 Magic Chef Washer(Model#W20HA5): The washer agitates, but does not spin. Found that the thrust bearing that lefts the brake assembly was worn out. I installed a new thrust bearing kit. Tested, works good!
Thrust Bearing Kit
1042142
You can browse our Maytag/Magic Chef/Admiral/Jenn-Air Washer Forum to see other problems and fixes related to these brands.
Categories : Washers
Comments (0)
Oct
04
Frigidaire Front Load Washer
Frigidaire Front Load Washer(Model#GLTF1670AS0): The water was not going out of the washer in the drain cycle. Found the water pump bearing had gone bad and locked-up. I Installed a new water pump in the washer, tested good.
Part#134051100
Water Pump
916709
Comments (0)
