Archive for December, 2006
18″ Frigidaire Dishwasher Repair Manual
Posted by: | CommentsHere is the smaller sized Frigidaire dishwasher that’s only 18″ instead of the normal 24″.
This dishwasher repair manual also covers Tappan, White-Westinghouse, Gibson, Kelvinator and Sears Kenmore(model# starting with 587).
You can order the Repair Manual by clicking the link or the picture.
Frigidaire Electronic Control Dishwasher Repair Manual
Posted by: | CommentsThis dishwasher repair manual also covers Tappan, White-Westinghouse, Gibson, Kelvinator and Sears Kenmore(model# starting with 587).
Amana Refrigerator Defrost Thermostat
Posted by: | CommentsAmana Bottom Mount Refrigerator(Model#BX21VW/P1325002WW): Not cooling in the refrigerator section. I took all the food out of the freezer and found that the back panel had a frost build-up on it. I took off the inside freezer back panel and ohmed the defrost thermostat for continuity, it had none. I installed a new defrost thermostat, worked great.
Part#10442411
Defrost thermostat
Frigidaire ‘Next Generation’ Side by Side Refrigerator Repair Manual
Posted by: | CommentsThis repair manual also covers Tappan, White-Westinghouse, Gibson, Kelvinator and Sears Kenmore(model# starting with 253).
Sears Kenmore Washer coupler
Posted by: | CommentsSears Kenmore Washer (Model#110.26902691): The problem was it would not spin at all, even though you could here the motor running. I found the motor coupler/coupling broken. I installed a new one, worked great.
Part#285753
Magic Chef Range
Posted by: | CommentsMagic Chef Range(Model#3868XRW): Oven not keeping proper temperature, doesn’t even get to the temperature set. Found the electronic control board and oven sensor faulty.
Electronic oven clock control
Part#7601P209-60
Oven sensor kit
Part#7430P009-60
Maytag Dryer Heating Element
Posted by: | CommentsMaytag dryer(Model#LDE312 series 02): Not heating properly. I found the element had broken and it was touching the heater housing, which is a grounded element. This caused the heater to be on all of the time, and not letting the timer advance in the auto dry cycles. This problem also made it so just 120 volts was passing through the element causing the low heat condition.
I installed a new heating element, worked great.
Heater Assembly
