Archive for February, 2007
Gibson Front-Load Washer
Posted by: | Comments2001 Gibson Front-Load Washer(model#GWT645RHS0): The washer wouldn’t drain out any water at all, you could hear the water pump humming, but the pump impeller wasn’t turning to drain the water. I found a lint clog in the pump, and some objects clogging it like coins, pins, etc. I looked inside the pump and one of the impeller fins was broken as well.
I installed a new water pump:
Water Pump
Part#134051100
Sears Kenmore Thermal Cut-Off
Posted by: | CommentsSears Kenmore Dryer(Model#110.66902691): The drum is turning but there is no heat at all. I took an ohm reading on the thermal cut-off thermostat with a Volt/Ohm Meter
and found no continuity. Its located on the heater housing.
Part#279816
Frigidaire Dryer Motor
Posted by: | CommentsFrigidaire Dryer(Model#GLER642AS3): When you press the start button, you can hear the motor humming, but it doesn’t turn the drum, but if you turn the drum with your hand while the motor is humming, it will start turning and continue to run. This always indicates a bad motor.
Part#131560100
Maytag Recalls Dishwashers Due to Fire Hazard
Posted by: | CommentsWASHINGTON, D.C. – The U.S. Consumer Product Safety Commission, in cooperation with the firm named below, today announced a voluntary recall of the following consumer product. Consumers should stop using recalled products immediately unless otherwise instructed.
Name of product: Maytag® and Jenn-Air® brand dishwashers
Units: About 2.3 million
Manufacturer: Maytag Corp., of Newton, Iowa
Hazard: Liquid rinse-aid can leak from its dispenser and come into contact with the dishwasher’s internal wiring which can short-circuit and ignite, posing a fire hazard.
Incidents/Injuries: Maytag has received 135 reports of dishwasher fires, resulting in product and/or property damage. Four injuries have been reported, including three reports of smoke inhalation and one serious hand laceration when operating a fire extinguisher to put out a fire in the dishwasher.
Description: The recall involves Maytag® and Jenn-Air® under counter or portable plastic tub dishwashers. The dishwashers have black, white, almond, bisque and stainless steel front panels. The following model and serial numbers are printed on a label located on the dishwasher’s plastic frame on top of or to the left of the door opening. Consumers should contact Maytag to determine if their dishwasher is included in this recall.
| Brand | Model numbers MUST begin with… |
AND serial numbers MUST end with… |
| Maytag® | MDB3, MDB4, MDB5, MDB6, MDB7, MDB8, MDB9, MDBD, MDC3, MDC4, MDC5, DWU9 |
SM, SQ, SS, SU, SW, SY, SZ, UB, UD, UF, UH, UK, UM, UQ, US, UU, UW, UY, UZ, WB, WD, WF, WH, WK, WM, WQ, WS, WU, WW, WY, WZ, YB, YD, YF, YH, YK, YM, YQ, YS, YU, YW, YY, YZ |
| Jenn-Air® | JDB3, JDB4, JDB5, JDB6, JDB7 |
Sold at: Department and appliance stores and by homebuilders nationwide from July 1997 through June 2001 for between $370 and $800.
Manufactured in: United States
Remedy: Consumers should immediately stop using these dishwashers, disconnect the electric supply by shutting off the fuse or circuit breaker controlling it and inform all users of the dishwasher about the risk of fire. Contact Maytag for either a free in-home repair, or a $75 cash back reimbursement following the purchase of a new Maytag®, Jenn-Air®, Whirlpool® or KitchenAid® dishwasher. Consumers should not return the dishwasher to the retailer where it was purchased, as retailers are not prepared to take units back.
Consumer Contact: For more information, contact Maytag Corporation at (800) 675-0535 anytime, or visit the firm’s Web site at www.repair.maytag.com
