Archive for April, 2007
GE/Hotpoint Replacement Ice Maker
Posted by: | CommentsHotpoint Refrigerator (Model#CSX22GRXAAA): The ice maker stopped working, it was getting water to it if you manually cycled it, but it stopped cycling on its own. The ice maker just wore out after 10 years. They have made a replacement electronic ice maker for these models now. I installed the new one, worked great!
Replacement icemaker kit, electronic
Part#WR30X10061
GE Refrigerator Defrost Problem in the Freezer
Posted by: | CommentsGE Refrigerator (Model#GSS22KGMB)
Here is a basic photo of a evaporator coil with massive frost build-up, but what part has failed?
Good Question, The first thing you do is move the defrost timer into defrost, if the defrost heater does not come on, then you know for sure that’s its either a bad heater or defrost thermostat. You would need to get a ohm meter to check the heater for continuity.
(With power off-refrigerator unplugged) the resistance of the heating element – it should measure
under 100 ohms (31 ohms typical). If it reads this then the heater is good. If not, you would need to replace the heater assembly.
Part#WR51X10053
Frigidaire Dishwasher Motor/Pump Assembly
Posted by: | CommentsFrigidaire Dishwasher(Model#FDB421RFR2): Not cleaning the dishes at all in any cycle. This has been a major issue for Frigidaire for many years now, but they have made a new Motor/Pump Assembly to solve this problem. Its works great!
Wash motor & pump kit
Part#154291501
