Archive for October, 2007
Oct
31
GE Range Top Element 8″
GE Range(model#JSP26G0N2WH): Right-Front top surface element burner(8″) not working.
I put my volt meter in the element terminal block and got a reading of 240 volts. That indicates its getting the proper voltage, but won’t turn on, because the element is bad.
Here’s the 8″ Right-Front Top burner element for this model:
Manufacturer part#WB30M2 is RepairClinic item#2797
Categories : Ranges
Comments (0)
Oct
11
Whirlpool Refrigerator Condenser Fan
Whirlpool Refrigerator (Model#ED25SMXRWR0): Not cooling well in both the refrigerator and freezer sections. Hot in between the doors on the cabinet middle frame.
Pulled the refrigerator out from the wall, then took off the lower back access cover to find that the condenser fan motor had stopped and wasn’t blowing air to keep the condenser cool, thus it was overheating the compressor and shutting it down on the compressor overload device.
Here’s the condenser fan motor for this model:
Manufacturer part#833697 is RepairClinic item#2790
2790
Categories : Refrigerators
Comments (0)
