Archive for September, 2008
Maytag Dryer Motor
Posted by: | CommentsMaytag Dryer(model#LDE4000ACW): Drum not turning at all, the motor is just buzzing, found the motor bearing bad.
Here’s the motor for this model:
Manufacturer’s Number: Y303358
Sears Kenmore Refrigerator Start Relay
Posted by: | CommentsSears Kenmore Refrigerator (model#106.51254101) Not cooling at all, found the compressor start relay bad, installed new one, worked great!
Here’s the compressor start relay for this model:
Manufacturer’s Number: 8201799
Sears Kenmore Washer Motor Coupling
Posted by: | CommentsSears Kenmore washer (model#110.28922790) Not spinning, but the motor is running. Found the motor coupling broken, Installed new motor coupling, worked great!
Here’s the motor coupling for this model – Part#285753A
Manufacturer’s Number: 285753A
Maytag Washer Idler Pulley
Posted by: | CommentsMaytag Washer (Model#SAV2555AWW) Not spinning, found the idler pulley stripped, the belt was burned in one spot due to the idler pulley. Installed new idler pulley and belt, worked great!
Idler Pulley
Manufacturer part number 40045001 is RepairClinic item number 550204
Belt
Manufacturer part#27001007 is RepairClinic item#919038
Whirlpool Water Inlet Valve
Posted by: | CommentsFreezer flooded and now ice maker not working – Appliance Blog Repair Forums
jharris fixed his Whirlpool refrigerator by installing a new water inlet valve.
Manufacturer’s Number: 4389177
Maytag Neptune Dryer Heating Element
Posted by: | CommentsMaytag Neptune MDE3000AYW too hot – Appliance Blog Repair Forums
Fastang fixed it!
Manufacturer’s Number: 307178
Maytag Neptune Front-Load Washer Control Board
Posted by: | CommentsNeptune MAH5500BWW won’t start… – Appliance Blog Repair Forums
KevinR fixed it!
Manufacturer part number 22004299 is RepairClinic item number 1032966
