Archive for October, 2008
Amana Refrigerator Defrost Timer
Posted by: | CommentsAmana Refrigertor(model#BC20HW): Not cooling properly. Turned the defrost timer into the defrost cycle, the defrost heater came on. Normal defrost cycle is about 20-40 minutes. Waited an hour and it didn’t come out of defrost, so that means the defrost timer is bad.
Here’s the defrost timer for this model:
Manufacturer part number R0168027 is RepairClinic item number 2256
Sears Kenmore Defrost Thermostat(Bi-Metal)
Posted by: | CommentsSears Kenmore refrigerator(model#1069430411): Not cooling properly, found frost build-up inside the freezer on the inside back panel, took the panel off and found all the evaporator coils frosted up. Ohm tested the defrost thermostat(bi-metal) for continuity while it was still frosty, and found no continuity. That indicates the defrost thermostat(bi-metal) is bad.
Here’s the defrost thermostat(bi-metal) for this model:
Manufacturer part number 2321799 is RepairClinic item number 1399517
KitchenAid Dishwasher Wash Motor
Posted by: | CommentsKitchenAid Dishwasher(model#KUDS01DJWH0): Wash motor just humming, locked-up, found bearing out.
Here’s the wash motor/sump pump assembly for this model:
Manufacturer’s Number: 8535150
White-Westinghouse Dryer Motor
Posted by: | CommentsWestinghouse Dryer(model#DE650JDD1): Dryer drum not turning, motor is just grinding when you push the start button. Motor bearing is bad.
Here’s the motor for this model:
Manufacturer part number 5300603185 is RepairClinic item number 94
