Archive for February, 2009
Whirlpool Duet Fill Valve
Posted by: | CommentsWhirlpool front-load washer(model#GHW9160PW1): Water doesn’t stop coming into the machine at all, Even when you unplug the washer, it still won’t stop the water from coming in.
You have to turn off the main water facet valves to the washer for the water to stop coming in.
It needs a new fill valve.
Here’s the fill valve for this model:
Manufacturer’s Number: 8181694
Cross Reference and Model Information
Made by Whirlpool. Whirlpool brands include Whirlpool, Maytag, KitchenAid, Jenn-Air, Amana, Magic Chef, and others.
Whirlpool also makes various appliance models for Sears / Kenmore.
Part Number 8181694 (AP3128776) is used with the following appliance models:
110.42822200, 110.42822201, 110.42824200, 110.42824201, 110.42826200, 110.42826201, 110.42832200, 110.42832201, 110.42834200, 110.42834201, 110.42836200, 110.42836201, 110.42922200, 110.42924200, 110.42926200, 110.42932200, 110.42934200, 110.42936200, 110.44832200, 110.44834200, 110.44836200, 110.44932200, 110.44934200, 110.44936200, 7MGHW9100MW0, 7MGHW9150PW0, 7MGHW9150PW1, 7MGHW9400PW0, 7MGHW9400PW1, GHW9100LQ0, GHW9100LQ1, GHW9100LQ2, GHW9100LQ2, GHW9100LW0, GHW9100LW1, GHW9100LW2, GHW9100LW2, GHW9150PW0, GHW9150PW1, GHW9150PW2, GHW9150PW3, GHW9160PW0, GHW9160PW2, GHW9160PW3, GHW9200LQ0, GHW9200LW0, GHW9250ML0, GHW9250ML1, GHW9250ML2, and more.
KitchenAid Bake Element
Posted by: | CommentsKitchenAid Range(model#KERC506HWH2): Oven not heating at all when set on bake. Took a voltage reading with my volt meter, and found 240 volts at the bake element in the back of the range, but the element didn’t come on and get red, which means the bake element is bad.
Here’s the bake element for this model:
Manufacturer part number 9750213 is RepairClinic item number 747678
GE Dishwasher not running
Posted by: | CommentsGE dishwasher(model#GSD5330D00WW): Motor wasn’t running, just humming, found the motor bad.
Here’s the motor/pump assembly for this model:
Manufacturer’s Number: WD26X10013
