Archive for April, 2009
Apr
27
Sears Kenmore Washer Drain Pump
Sears Kenmore front-load washer(model#110.47532601): Making grinding sounds when the drain pump is running, found the drain pump impeller bearing bad, installed a new drain pump worked great!
Here’s the drain pump for this model, The drain pump changes from part#8540024 to part#W10130913:
Manufacturer part number W10130913 is RepairClinic item number 1373005
Categories : Washers
Comments (0)
Apr
14
Sears Kenmore Dryer Thermal Fuse
Sears Kenmore Dryer(model#110.66832500): Dryer wasn’t turning on at all when you pressed the push-to-start switch. I used my ohm meter to check for continuity on the thermal fuse terminals, with the dryer unplugged, found no continuity. Installed new thermal fuse, worked great!
Here’s the thermal fuse for this model:
Manufacturer’s Number: 3392519
icon
icon
icon
Categories : Dryers
Comments (0)
WASHINGTON, D.C. – The U.S. Consumer Product Safety Commission, in cooperation with the firm named below, today announced a voluntary recall of the following consumer product. Consumers should stop using recalled products immediately unless otherwise instructed.
Name of Product: GE Profile™ Freestanding Dual Fuel Ranges
Units: About 28,000
Manufacturer: GE Consumer & Industrial, of Louisville, Ky.
Hazard: The wiring in the rear of the range can overheat, posing a fire and burn hazard to consumers.
Incidents/Injuries: GE is aware of 47 reports of overheated wiring, including 33 reports of wiring that caught fire. Of these, one fire caused structural damage to the home and there have been 14 reports of minor property damage. No injuries have been reported.
Description: This recall involves GE Profile 30” Freestanding Duel Fuel ranges. The ranges were sold in white, black, bisque and stainless steel. The following model and serial numbers can be found on the left inside corner of the bottom drawer.
Brand Model Number Begins With:
GE Profile J2B900
Serial Number Begins With:
LD, MD, RD, SD, TD, VD, ZD, AF, DF, FF, GF, HF, LF, MF
GE Profile J2B915
MF, RF, SF, TF, VF, ZF, AG, DG, FG, GG, HG, LG, MG, RG, SG, TG, VG, ZG
Sold at: Department and appliance stores nationwide from June 2002 through December 2005 for between $1,300 and $2,000.
Manufactured in: Mexico
Remedy: Consumers should immediately stop using the oven and contact GE for a free repair. Consumers can continue to use the cooktop burners.
Consumer Contact: For additional information, contact GE toll-free at (888) 352-9764 between 8 a.m. and 8 p.m. Monday through Friday, and between 9 a.m. and 3 p.m. Saturday ET, or visit the firm’s Web site at www.geappliances.com
J2B900
J2B900
J2B915
J2B915
TAG LOCATION
Categories : Recalls
Comments (0)
