Archive for May, 2009
May
19
Sears Kenmore Defrost Thermostat
Sears Kenmore Refrigerator(Model#596.75529400): Not cooling properly. I found the evaporator, that’s located inside the freezer behind the back panel, all frosted up heavily. Before you defrost it always ohm the defrost thermostat for continuity. I did a ohm test on it for continuity with an ohm meter, found no continuity at all. Installed new defrost thermostat, worked great!
Here’s the defrost thermostat for this model:
Manufacturer’s Number: 67003426
icon
icon
icon
Categories : Refrigerators
Comments (0)
May
08
Sears Kenmore Start Device Relay
Sears Kenmore side by side refrigerator(model#106.50542001): Not cooling, pulled the refrigerator out from the wall, then removed the lower back access panel, unplugged the refrigerator first, then removed the start device relay from the side of the compressor and shook it, it rattled alot. Whenever it rattles like that, its always broken inside.
We have a thread in our appliance repair forums on this issue that explains how to check it:
http://www.applianceblog.com/mainforums/showthread.php?t=1232
Here’s the start device relay for this model:
Manufacturer’s Number: 8201799
icon
icon
icon
Part Number 8201799 (AP3873993) replaces 2261634, 2261635, 2261636, 2261637, 2313405, 2313407, 2188393, 2188504, 2204306, 2188505, 2204412, 2188506, 2204307, 2188507, 22004413, 2204413.
Made by Whirlpool. Whirlpool brands include Whirlpool, Maytag, KitchenAid, Jenn-Air, Amana, Magic Chef, and others.
Whirlpool also makes various appliance models for Sears / Kenmore.
Part Number 8201799 (AP3873993) is used with the following appliance models:
106.50022000, 106.50027000, 106.50032000, 106.50037000, 106.50202990, 10648062891, 10648067891, 10648262891, 10648267891, 10648562891, 10650203990, 10650209990, 10650262990, 10659021991, 10659028991, 10659062990, 10659067990, 10659069990, 7ED20TQXFW01, 7GD22DFXFW00, 7GD25DFXFW00, 7GD25SFXHS00, 8ED20TKXFN01, 8ED20TKXFW01, 8ED20ZKXFN01, 8ED20ZKXFW01, 8ED22PQXFN01, 8ED22PQXFW01, ED20TKXFN01, ED20TKXFT01, ED20TKXFW01, ED20TQXFN01, ED20TQXFT01, ED20TQXFW01, ED22CQXHB00, ED22CQXHN00, ED22CQXHT00, ED22CQXHW00, ED22GWXFN01, ED22GWXFW01, ED22LFXHB00, ED22LFXHT00, ED22LFXHW00, ED22PEXHB00, ED22PEXHT00, ED22PEXHW00, ED22QFXHB00, ED22QFXHN00, ED22QFXHT00, ED22QFXHW00, and more.
Comments (0)
