Archive for June, 2009
Sears Kenmore Washer Lid Switch
Posted by: | CommentsSears Kenmore Washer(model#110.23034101): Washer will fill with water then stop and not do anything, also when you put it spin, nothing happens. Found the lid switch bad.
What you do to check it is to get a volt/ohm meter and put the the meter on the ohms setting, then put the meter probes in the black & red connectors from the lid switch, then push the lid switch down, if your meter reads 0-1 ohms then its good, if the meter reads nothing at all its bad.
Here’s the lid switch for this model:
Manufacturer’s Number: 8054980
Made by Whirlpool. Whirlpool brands include Whirlpool, Maytag, KitchenAid, Jenn-Air, Amana, Magic Chef, and others.
Whirlpool also makes various appliance models for Sears / Kenmore.
Part Number 8054980 (AP3020600) is used with the following appliance models:
110.20052991, 110.20052992, 110.20052993, 110.20056993, 11020052994, 11020056991, 11020056992, 11020056994, 11020072990, 11020072991, 11020072992, 11020072993, 11020092990, 11020092991, 11020092992, 11020092993, 11020094992, 11020094993, 11020096990, 11020096991, 11020096992, 11020096993, 11020097990, 11020097991, 11020097992, 11022032100, 11022032101, 11022032102, 11022036100, 11022036101, 11022036102, 11022042100, 11022042101, 11022042102, 11022052100, 11022052101, 11022052102, 11022054100, 11022054101, 11022054102, 11022056100, 11022056101, 11022056102, 11023012100, 11023012101, 11023012102, 11023014100, 11023014101, 11023014102, 11023022100, and more.
Sears Kenmore Refrigerator Condenser Motor
Posted by: | CommentsSears Kenmore Side by Side Refrigerator(model#106.56563400): Not cooling well, freezer items not hard enough and refrigerator section warming up too. When I touched the middle cabinet divider it was very hot. I pulled the refrigerator out from the wall, then took off the lower back access cover and found the condenser fan motor not turning, it had gone bad.
Here’s the condenser fan motor for this model:
Manufacturer’s Number: W10124096
Part Number W10124096 (AP4318657) replaces 2206036, 2188727, 2188729, 2206005, 2315538, W10130108.
Part Number W10124096 (AP4318657) is used with the following appliance models:
CS22AFXKB05, CS22AFXKS05, CS22AFXKT05, CS22TKXNQ00, CS25AFXKQ04, CS25AFXKT04, ED0GTKXMT00, ED2CHQXKB07, ED2CHQXKQ07, ED2CHQXKT07, ED2GHGXMB02, ED2GHGXMQ02, ED2GTKXNQ00, ED2GTKXNQ01, ED2LHAXMB11, ED2LHAXML11, ED2LHAXMQ11, ED2LHAXMT11, ED5CHQXKB04, ED5CHQXKB06, ED5CHQXKQ04, ED5CHQXKQ06, ED5CHQXKT04, ED5CHQXKT06, ED5FHAXNB01, ED5FHAXNL01, ED5FHAXNQ01, ED5FHAXNT01, ED5FHAXSB00, ED5FHAXSB01, ED5FHAXSB02, ED5FHAXSL00, ED5FHAXSL01, ED5FHAXSL02, ED5FHAXSQ00, ED5FHAXSQ01, ED5FHAXSQ02, ED5FHAXSS00, ED5FHAXSS01, ED5FHAXSS02, ED5FHAXST00, ED5FHAXST01, ED5FHAXST02, ED5FHEXNB01, ED5FHEXNB02, ED5FHEXNL01, ED5FHEXNL02, ED5FHEXNL03, ED5FHEXNQ01, ED5FHEXNQ02, and more.
