• Home
  • Appliance Repair Forums
  • Appliance Parts
  • Appliance Market Place
Subscribe to Appliance Blog – Appliance Repair Blog Forums
Get the latest updates delivered via email
Appliance Blog | Promote Your Page Too
Follow ApplianceBlog on Twitter
Archive for July, 2009
Jul
30
Frigidaire Recalls Clothes Washers Due to Fire Hazard
WASHINGTON, D.C. – The U.S. Consumer Product Safety Commission, in cooperation with the firm named below, today announced a voluntary recall of the following consumer product. Consumers should stop using recalled products immediately unless otherwise instructed.
Name of Product: Crosley®, Frigidaire®, Kelvinator®, Kenmore®, Wascomat®, and White-Westinghouse® clothes washers
Units: About 35,000
Distributor: Frigidaire, of Cleveland, Ohio
Hazard: An internal defect in the washer’s drain pump can cause heat to build up, posing a fire hazard to the consumer.
Incidents/Injuries: No incidents or injuries have been reported.
Description: This recall involves the Crosley®, Frigidaire®, Kelvinator®, Kenmore®, Wascomat®, and White-Westinghouse® top load washers, 3.1 cubic foot front load washers and laundry centers.
Product Type Brand Model Serial Number
Top Load Washer Crosley, Frigidaire, Kelvinator,
White- Westinghouse
CTW100FW GLWS1749FS SWS833HS
FTW3011KW KWS1349DS SWX703HQ
FTW3014KW MWS939AS SWX703HS
FWS1233FS SWS1233HQ WWS833FS
FWS933FS SWS1233HS WWTW3000KW
GLWS1439FC SWS1339HS
GLWS1439FS SWS1649HS
XC90306228 to XC91606302
Front Load Washer Crosley, Frigidaire, Wascomat,
White- Westinghouse
CFW2000FW FTF530FS WE17N
FCCW3000FS GLTF1570FS WTF330HS
FTF1240FS WE17M
XC90501765 to XC91607678
Laundry Center Crosley, Frigidaire, Kenmore,
White -Westinghouse
97812 CLCE900FW GLET1142FS
97912 FEX831FS GLGH1642FS
97962 FGX831FS GLGT1031FS
C97812 FLGB8200FS GLGT1142FS
C97912 GCET1031FS MEX731CFS
C97962 GLEH1642FS SWSG1031HS
CLCE500FW GLET1031FS SWXG831HS
XE85104013 to XE91603486
          *Not all serial numbers within these ranges are affected.
Model and serial numbers can be located as follows:
Top load washer = open the product’s lid, and the model and serial number are located inside the product’s lid, on the top, right hand corner.
Front load washer = open the door, and the model and serial number are located with other information at the top, center.
Laundry center = open the door to the dryer, and the model and serial number are located on the outer edge of the door nearest the door’s handle.
Sold by: Sears and other retailers nationwide from February 2009 through May 2009 for between $300 and $1100.
Manufactured in: United States
Remedy: Consumers should immediately unplug and stop using the machine. Consumers should contact Frigidaire or Sears (if unit was purchased there) to schedule a free repair.
Consumer Contact: For additional information, contact Frigidaire at (800) 734-4519 between 8 a.m. and 11 p.m. ET Monday through Saturday, or visit the firm’s Web site at www.laundrypumprecall.com. For consumers who purchased their product at Sears, call Sears toll free at (888) 549-5870 between 8 a.m. and 10 p.m. ET Monday through Saturday, or visit Sear’s Web site at www.sears.com
More information: http://www.cpsc.gov/cpscpub/prerel/prhtml09/09292.html
Categories : Recalls
Comments (0)
Jul
29
Frigidaire Washer Loud & Leaking
Frigidaire Front-Load Washer(Model#FWT445GES2): Found the rear tub bearing is out and the middle tub seal leaking water.
You can either replace the complete outer tub assembly with the bearing already installed or if your really into a challenge just change the bearing alone as described here:
http://www.applianceblog.com/mainforums/showthread.php?t=237
Manufacturer part number 131525500 is RepairClinic item number 407639
Rear outer tub assembly with bearing and shaft seal
 Also order the tub seal:
 Manufacturer part number 134146100 is RepairClinic item number 936915
Categories : Washers
Comments (0)
Jul
16
Frigidaire Dryer Squeaking
Frigidaire Dryer(Model#FDE648GHS0): Loud squeaking noise on every load. Found the front felt pads and rear bearing  worn out.
There is a great Dryer Preventive Maintenance Kit available for these models and the Sears Kenmore dryers that start with model#417.
Dryer preventative maintenance kit 1992 – 2001
Manufacturer part number 5304461262 is RepairClinic item number 1261075
Dryer preventative maintenance kit 1992 - 2001
Dryer preventative maintenance kit 2002 and up
Manufacturer part number 5304457724 is RepairClinic item number 1198622
Categories : Dryers
Comments (0)
Login
To ask appliance repair questions, please register at our forums: Appliance Repair Forums
Search Our Blog
Categories
  • Accessories (8)
  • Air Conditioners-Window/Wall (5)
  • Amana – Speed Queen – Caloric (7)
  • Appliance Blog Forum Links (68)
  • Dishwashers (34)
  • Dryers (44)
  • Entertainment News (1)
  • Frigidaire, Tappan, Gibson, White Westinghouse, Kenmore models 417 & 253 Appliance Repair Manuals (13)
  • GE – Hotpoint – RCA (9)
  • General Appliance Talk (42)
  • Holidays (13)
  • Maytag – Admiral – Magic Chef – Jenn Air (28)
  • Ranges (33)
  • Recalls (12)
  • Refrigerators (62)
  • Repair Manuals (1)
  • Shop New Appliances (1)
  • The Daily Diary (138)
  • The Daily Diary 2 (129)
  • Uncategorized (4)
  • Washers (47)
  • Weather (2)
  • Whirlpool – Sears Kenmore – KitchenAid (12)
Recent Comments
  • Jake on Washing machine stainless steel fill hoses
  • teachmemetric on Washing machine stainless steel fill hoses
  • adamwarlock on Overload/Relay
  • Jerry on Maytag Recalls Dishwashers Due to Fire Hazard
  • VickiSue on Sears Kenmore Washer Lid Switch
  • Curt on Sears Kenmore Washer Lid Switch
  • jkmarshall on Maytag Refrigerator Adaptive Defrost Board
  • jdesmarteau on Maytag Dryer Thermal Fuse
Tags
Adaptive Defrost Board air conditioner bearing Christmas cleaner cleaning clock condenser cooktop coupling Crosley defrost thermostat Dishwasher drain pump dryer fan Frigidaire GE heating element Hotpoint ice maker Kenmore lid switch Magic Chef maintenance Maytag meter motor oven oven control board oven igniter range Recall refrigerator seal Sears Sears Kenmore start device relay thanksgiving thermal fuse thermometer washer water filters water pump Whirlpool
Archives
  • May 2013 (1)
  • February 2013 (1)
  • December 2012 (1)
  • November 2012 (1)
  • September 2012 (1)
  • August 2012 (1)
  • July 2012 (1)
  • June 2012 (3)
  • May 2012 (2)
  • April 2012 (1)
  • March 2012 (1)
  • February 2012 (1)
  • December 2011 (2)
  • November 2011 (2)
  • September 2011 (1)
  • August 2011 (1)
  • July 2011 (1)
  • June 2011 (1)
  • May 2011 (1)
  • April 2011 (1)
  • March 2011 (1)
  • February 2011 (2)
  • January 2011 (2)
  • December 2010 (2)
  • November 2010 (4)
  • October 2010 (2)
  • September 2010 (1)
  • August 2010 (1)
  • July 2010 (1)
  • June 2010 (2)
  • May 2010 (1)
  • April 2010 (1)
  • March 2010 (1)
  • February 2010 (1)
  • January 2010 (1)
  • December 2009 (3)
  • November 2009 (3)
  • October 2009 (1)
  • September 2009 (2)
  • August 2009 (2)
  • July 2009 (3)
  • June 2009 (2)
  • May 2009 (2)
  • April 2009 (3)
  • March 2009 (2)
  • February 2009 (3)
  • January 2009 (3)
  • December 2008 (3)
  • November 2008 (6)
  • October 2008 (11)
  • September 2008 (8)
  • August 2008 (7)
  • July 2008 (19)
  • June 2008 (17)
  • May 2008 (20)
  • April 2008 (16)
  • March 2008 (6)
  • February 2008 (2)
  • January 2008 (1)
  • December 2007 (2)
  • November 2007 (1)
  • October 2007 (2)
  • September 2007 (1)
  • August 2007 (1)
  • July 2007 (1)
  • May 2007 (2)
  • April 2007 (3)
  • March 2007 (4)
  • February 2007 (4)
  • January 2007 (12)
  • December 2006 (11)
  • November 2006 (11)
  • October 2006 (11)
  • September 2006 (5)
  • August 2006 (3)
  • July 2006 (3)
  • June 2006 (3)
  • May 2006 (8)
  • April 2006 (8)
  • March 2006 (10)
  • February 2006 (9)
  • January 2006 (10)
  • December 2005 (13)
  • November 2005 (12)
  • October 2005 (11)
  • September 2005 (13)
  • August 2005 (14)
  • July 2005 (15)
  • June 2005 (14)
  • May 2005 (17)
  • April 2005 (19)
  • March 2005 (21)
  • February 2005 (22)
  • January 2005 (29)
  • December 2004 (35)
  • November 2004 (40)
  • October 2004 (31)
  • September 2004 (31)
  • August 2004 (29)
Copyright © 2013 All Rights Reserved
Flexx Theme by iThemes
Powered by WordPress
