• Home
  • Appliance Repair Forums
  • Appliance Parts
  • Appliance Market Place
Subscribe to Appliance Blog – Appliance Repair Blog Forums
Get the latest updates delivered via email
Appliance Blog | Promote Your Page Too
Follow ApplianceBlog on Twitter
Archive for December, 2012
Dec
15
Maintenance Tips for your Range Stove Oven
Maintenance Video
  • Range/Stove/Oven Maintenance
    Range Maintenance Tips
    To purchase replacement parts for your range, search http://www.repairclinic.com/Shop-For-Parts using your appliance’s model number.
Broiler pan
The broiler pan that comes with most range/ovens is porcelain-coated steel. Clean it with a non-abrasive cleanser. If you want to replace the broiler pan instead, we offer one called the Broiler Pan and Insert.
Control panel
Most range/oven control panels are glass and/or painted metal. You can safely use non-abrasive cleaners on these surfaces. We offer a wide selection of Range/Stove/Oven Cleaner and Deodorizer Parts.
Note: Never spray cleaners directly onto the control panel. Instead, put some cleaner on a soft, damp rag, then wipe the surface.
Cooktop
You can clean any porcelain cooktop with a non-abrasive cleanser.
Note: Don’t pour the cleanser directly onto the cooktop. Instead, put some cleaner on a soft, damp rag, then wipe the surface.
Burner drip pans (bowls)
You usually need to replace the drip pans or bowls beneath the grates on a gas stove/range and beneath the heating element on an electric stove/range every 2 to 3 years. That’s because, once they’re stained, it’s usually not possible to clean them completely.
If you have your appliance model number, you can order replacement original bowls by going to our Shop-For-Parts section. Or, you can purchase universal bowls from our Universal Range/Stove/Oven Drip Bowl & Drip Pan Parts section.
Glass cooktops and windows
Always clean glass and ceramic cooktops only with products made for this purpose–such as the Glass Cooktop Cleaner we carry.
Clean your glass oven windows with any oven glass cleaner. But be careful not to clean glass surfaces that are hot!
Knob care
You may be able to safely clean the knobs on your range/oven with a little dish detergent and a damp rag. But, if the numbers or lettering have worn away, you may need to replace the knobs.
If you have your model number, you can visit our Shop For Parts area to purchase replacement original knobs for your range/oven. We also offer universal knob sets that fit a wide variety of different ranges/ovens.
Light bulbs
You can replace the light bulb(s) in your range/oven, though you may need to remove a glass covering or dome to reach it. Most interior oven lights require a universal 40 watt appliance bulb.
Oven
If your oven is self-cleaning, consult the owner’s manual for instructions on how to use this feature. The self-cleaning feature works by heating the interior of the oven to a temperature so hot that it incinerates the residue inside the oven. Normally, it is not a good idea to clean the interior of a self-cleaning oven with a spray cleaner; however, refer to your owner’s manual or contact the manufacturer of your oven for further information.
To clean a non-self-cleaning oven, use one of the many oven cleaners that are available at grocery and hardware stores.
Solid burner element
Some stove/ranges have heating element burners that are solid metal–there’s no coil, and the stove/range isn’t glass or ceramic. You can clean these solid burners using our Solid Surface Element Cleaner.
Categories : Ranges
Comments (0)
Login
To ask appliance repair questions, please register at our forums: Appliance Repair Forums
Search Our Blog
Categories
  • Accessories (8)
  • Air Conditioners-Window/Wall (5)
  • Amana – Speed Queen – Caloric (7)
  • Appliance Blog Forum Links (68)
  • Dishwashers (34)
  • Dryers (44)
  • Entertainment News (1)
  • Frigidaire, Tappan, Gibson, White Westinghouse, Kenmore models 417 & 253 Appliance Repair Manuals (13)
  • GE – Hotpoint – RCA (9)
  • General Appliance Talk (42)
  • Holidays (13)
  • Maytag – Admiral – Magic Chef – Jenn Air (28)
  • Ranges (33)
  • Recalls (12)
  • Refrigerators (62)
  • Repair Manuals (1)
  • Shop New Appliances (1)
  • The Daily Diary (138)
  • The Daily Diary 2 (129)
  • Uncategorized (4)
  • Washers (47)
  • Weather (2)
  • Whirlpool – Sears Kenmore – KitchenAid (12)
Recent Comments
  • Jake on Washing machine stainless steel fill hoses
  • teachmemetric on Washing machine stainless steel fill hoses
  • adamwarlock on Overload/Relay
  • Jerry on Maytag Recalls Dishwashers Due to Fire Hazard
  • VickiSue on Sears Kenmore Washer Lid Switch
  • Curt on Sears Kenmore Washer Lid Switch
  • jkmarshall on Maytag Refrigerator Adaptive Defrost Board
  • jdesmarteau on Maytag Dryer Thermal Fuse
Tags
Adaptive Defrost Board air conditioner bearing Christmas cleaner cleaning clock condenser cooktop coupling Crosley defrost thermostat Dishwasher drain pump dryer fan Frigidaire GE heating element Hotpoint ice maker Kenmore lid switch Magic Chef maintenance Maytag meter motor oven oven control board oven igniter range Recall refrigerator seal Sears Sears Kenmore start device relay thanksgiving thermal fuse thermometer washer water filters water pump Whirlpool
Archives
  • May 2013 (1)
  • February 2013 (1)
  • December 2012 (1)
  • November 2012 (1)
  • September 2012 (1)
  • August 2012 (1)
  • July 2012 (1)
  • June 2012 (3)
  • May 2012 (2)
  • April 2012 (1)
  • March 2012 (1)
  • February 2012 (1)
  • December 2011 (2)
  • November 2011 (2)
  • September 2011 (1)
  • August 2011 (1)
  • July 2011 (1)
  • June 2011 (1)
  • May 2011 (1)
  • April 2011 (1)
  • March 2011 (1)
  • February 2011 (2)
  • January 2011 (2)
  • December 2010 (2)
  • November 2010 (4)
  • October 2010 (2)
  • September 2010 (1)
  • August 2010 (1)
  • July 2010 (1)
  • June 2010 (2)
  • May 2010 (1)
  • April 2010 (1)
  • March 2010 (1)
  • February 2010 (1)
  • January 2010 (1)
  • December 2009 (3)
  • November 2009 (3)
  • October 2009 (1)
  • September 2009 (2)
  • August 2009 (2)
  • July 2009 (3)
  • June 2009 (2)
  • May 2009 (2)
  • April 2009 (3)
  • March 2009 (2)
  • February 2009 (3)
  • January 2009 (3)
  • December 2008 (3)
  • November 2008 (6)
  • October 2008 (11)
  • September 2008 (8)
  • August 2008 (7)
  • July 2008 (19)
  • June 2008 (17)
  • May 2008 (20)
  • April 2008 (16)
  • March 2008 (6)
  • February 2008 (2)
  • January 2008 (1)
  • December 2007 (2)
  • November 2007 (1)
  • October 2007 (2)
  • September 2007 (1)
  • August 2007 (1)
  • July 2007 (1)
  • May 2007 (2)
  • April 2007 (3)
  • March 2007 (4)
  • February 2007 (4)
  • January 2007 (12)
  • December 2006 (11)
  • November 2006 (11)
  • October 2006 (11)
  • September 2006 (5)
  • August 2006 (3)
  • July 2006 (3)
  • June 2006 (3)
  • May 2006 (8)
  • April 2006 (8)
  • March 2006 (10)
  • February 2006 (9)
  • January 2006 (10)
  • December 2005 (13)
  • November 2005 (12)
  • October 2005 (11)
  • September 2005 (13)
  • August 2005 (14)
  • July 2005 (15)
  • June 2005 (14)
  • May 2005 (17)
  • April 2005 (19)
  • March 2005 (21)
  • February 2005 (22)
  • January 2005 (29)
  • December 2004 (35)
  • November 2004 (40)
  • October 2004 (31)
  • September 2004 (31)
  • August 2004 (29)
Copyright © 2013 All Rights Reserved
Flexx Theme by iThemes
Powered by WordPress
