Go Back   ApplianceBlog.com - Appliance Repair Forums > Appliance Repair Talk > Dishwashers > Bosch
Old October 7th, 2007, 03:48 PM
dlefeve is on a distinguished road
Default Test program results?
I have a Bosch SHU43XX dishwasher that won't shut off by itself. It seems stuck in a "drain" mode, with the CLEAN light on. I did find solder joint problems on the controller board and bridged over one relay pin connection - with no change, whatever, in operation.
I put it in "test program" and don't understand what all is supposed to happen. Is the dishwasher supposed to run through its entire operation (90+ minutes)? After a little while the RINSE/DRY light was on and am wondering if this means there's a problem with the water level switch - or that I didn't wait long enough for the cycles to continue (at which time that light might have gone out and others might have come on). Is there any further explanation of the TEST PROGRAM than what is found at: http://www.applianceaid.com/boschDW.html#test
I'm really concerned about replacing the whole controller assembly, only to find out a water level or float switch is the simpler (and much less expensive) problem.
Thanks for your help. This is a fantastic source of help and information.
Doug
appliance-repair.org program blackhorse70 General Appliance Chat 19 May 13th, 2009 05:10 PM
KitchenAid (Whirlpool) DISHWASHER Runs to Infinity - how test TStat? pgtr Washers 2 December 5th, 2006 10:09 PM
frigidaire gas dryer no heat - how 2 test parts? peanut3122 Frigidaire/Electrolux 4 December 1st, 2006 11:08 AM
Hotpoint washer saying 'TEST' batleyvic GE/Hotpoint 3 September 4th, 2006 11:55 AM
Kenmore test yields wrong beeps MikeWalsh Sears Kenmore 2 August 2nd, 2005 04:36 PM
