Go Back   ApplianceBlog.com - Appliance Repair Forums > Appliance Repair Talk > Dishwashers > Bosch
Old October 10th, 2007, 06:19 AM
Steve100 is on a distinguished road
Angry Fixed solder joint - now what?
My Bosch SHU5306 had the burnt solder joint on the circuit board. I soldered it and the dishwasher worked fine, but only for about three weeks. Now it runs down to "1" and doesn't finish the cycle again. I checked my solder on the circuit board and it's still fine. I ran the test and it came up with a "2" pointing to a heater problem now. Does anyone have any ideas? Has anyone else that has soldered the circuit board also had a further failure?
Old February 11th, 2008, 05:08 PM
SteinkeBeyer is on a distinguished road
Angry Fixed Solder joint worked for about 4 months
I have had the same experience with a SHI6802/U06. That is dishwasher would not countdown, because it could not come up to temperature. I took repaired the control module by soldering the joint that supplies current to the heater. The dishwasher has worked great for about one month. Now it hang on the counter because it will not come up to temperature. I took the control unit apart and my repaired solder joint is in tact and no sign of burned wiring or any other component failure. When I run the diagnostics, I get the same error code as I did before I fixed the solder joint which is "1" Aqua Sensor.
Anyone have any thoughts, please pass them on.
Last edited by SteinkeBeyer; February 11th, 2008 at 05:10 PM.. Reason: typo grammar
Something melted near the compressor and my dad thinks he fixed it with tape. monkeypox GE/Hotpoint 3 July 1st, 2007 11:08 AM
Fixed one problem, caused another lloydbishop KitchenAid 1 April 30th, 2007 10:00 PM
Kenmore no drain no spin and how I fixed it. savvy_corax Sears Kenmore 3 April 18th, 2007 09:46 AM
Whirlpool Calypso -frozen u joint? Jojen Whirlpool/KitchenAid 2 August 4th, 2006 03:51 PM
