Results 1 to 10 of 19
Thread: Bosch SHU43 problem
    JohnF is offline Member
    Aug 2005
    Default Bosch SHU43 problem
    I have followed the advice on this forum. Very helpful, but I am stuck. I found the burnt solder joint on the circuit board. I resoldered it. Does not seem to have fixed the problem. The machine just runs and runs.
    If you have a burnt solder joint, do you need to get a new board?
    I measured internal temp. About 160 degrees. So I know that the heater is working.
    I have the clean light always on. Which leads me to a bad NTC, but I do not get the other symptoms on diagnostic that the NTC is bad. It says that the pump will stop shortly after test mode starts. It does not. It just keeps running.
    Anybody have any advice?
    Oct 2004
    Most times yes.....esp if under the 5 year parts warranty!
    http://www.applianceaid.com/
    NEW Appliance Repair Aid
    http://www.jrappliance.ca
    JRAppliance
    Aug 2005
    Unfortunately, I am out of warranty.
    Since the heater was working when I measured the temp last night 160 degrees, and it still had the same problem would you think the temp sensor is defective?
    Or should I start by buying the replacement circuit board?
    Oct 2004
    A test that may help....
    http://www.applianceaid.com/boschDW.html
    JRAppliance
    Aug 2005
    I tried the test
    "If NTC probe (f2/f4) has failed (opened), CLEAN light will come on immediately and testing will end shortly after water has started circulating."
    The clean light is on for the duration of the test. But the test does not stop. It just keeps on going.
    That is what I do not understand.
    Oct 2004
    Another NTC test....Normal resistance is approx. 50K ohms @ room temperature. Resistance decreases as temp. increases.
    If ok, sounds like new control time.
    JRAppliance
    Aug 2005
    OK, I checked the resistance on the NTC. Temperature of water in bottom of dishwasher was 70 degrees. Resistance was 63.7K ohms. Is that close enough to spec? Or does that mean NTC is bad. I am not sure how big a range is acceptable.
    Thanks for the help!!
    Oct 2004
    -Sounds- too high to me....might be worth replacing. + or - 5% is usually ok.
    JRAppliance
    jamesc is offline Member
    Sep 2005
    ny
    I have a similar issue - water not hot and runs forever, had to replace the control module cover - then this issue with low water temp and runs forever. looked at the circuit brd and it had a burnt solder joint, reheated but still not running correctly. My delima is do I change the heat or the control pcb firts? Any suggestions are appreciated..
    Oct 2004
    My guess, control board.
    JRAppliance
  1. Bosch Dishwasher Problem
    By DanM in forum Bosch
    Last Post: July 2nd, 2007, 09:48 PM
  2. Bosch Detergent Dispenser Problem
    By ron k in forum Bosch
    Last Post: January 3rd, 2007, 08:58 AM
  3. Bosch SHU5305UC/14 heating problem
    By alexk in forum Bosch
    Last Post: June 17th, 2006, 07:23 PM
  4. Bosch SHU43 cleaning problem question
    By smondazzi@comcast.net in forum Bosch
    Last Post: April 11th, 2006, 07:12 AM
  5. Bosch SHU40 problem
    By iceman in forum Bosch
    Last Post: December 1st, 2005, 04:57 PM
