December 27th, 2007, 11:31 AM
Bosch dishwasher
I have a Bosch dishwasher model # SHV4803UC/U07
had sink backup over weekend and fill the dishwasher, tech who installed did not install an air vent, got clog taken care of and turned on dishwasher it pumped out the water but of course did not run, have been readiing the postings, I think the float switch needs to be reset, have taken out filter and cleaned also, thought I could get to it under filter screen, not, do I have to pull out the dishwasher and access it from the side?
thanks
December 27th, 2007, 12:54 PM
bosch diswasher
ok so I pulled the dishwasher out removed left side panel and found float switch and reset
December 27th, 2007, 02:06 PM
bosch dishwasher float switch
ok so reset and turned on was working fine, turned it off to reinstall under counter, got everything back and turned back on not filling with water again, pulled back out and checked everything (water on) all water vacumned up out of pan with shop vac does the diswasher itself need to be reset currently it is still out. any suggestions most helpful
December 28th, 2007, 12:29 AM
Unfortunately, I don't work on Bosch products. Jeff1 has a good Bosch help page here:
Bosch dishwashers
In the first post.
You can also message him and see if he knows.
December 28th, 2007, 06:15 AM
resetting float switch bosch dishwasher
thanks anyway, but I got it fixed, after flipping through the other postings with similar problem.
after I pulled the dishwasher out and removed the side panel again, making sure all water was out of the very bottom pan, I took about 3 gallons of water and put into tub, after I shut the door the washer started cycling again, I left it out this time to be sure and it completed the wash cycle. reinstalled all looks fine.
December 28th, 2007, 11:52 AM
Sounds good.
By mpadberg in forum Bosch
Last Post: October 19th, 2012, 09:13 AM
By pointnshoot in forum Bosch
Last Post: April 21st, 2011, 10:45 AM
By 10009575 in forum Bosch
Last Post: October 11th, 2007, 05:38 AM
Last Post: July 2nd, 2007, 09:48 PM
By sparks70b in forum Bosch
Last Post: October 11th, 2006, 06:12 PM
