Go Back   ApplianceBlog.com - Appliance Repair Forums > Appliance Repair Talk > Dishwashers > Bosch
Old May 11th, 2008, 09:12 AM
slackkeymike is on a distinguished road
Default Bosch SHU3326UC/14 Won't Drain
It also makes a strange sound a certain points in te cycle, like little plastic beads are swirling around in the bottom somewhere. That can't be good. So, what do I do?
Mike
Old May 13th, 2008, 11:45 AM
Default bosch
pull the drain line off of the disposal/air gap/ drain connection and HOLD the drain line in bucket while canceling program(causes drain cycle run) to clear any junk. then look in sump(bottom) of dishwasher under screens to find seeds/glass/knife blade etc. glass is invisible in water so use caution or tool to probe. reconnect drain line to drain and make sure that it is not draining when started(there is such a thing as stuck wash motor, which presents as water in bottom and dirty dishes) to isolate the drain pump as the issue. some have cover with torx screw, remove torx, cover and look for glass or debris, replace cover and screw and sump screens.
LinkBack to this Thread: http://www.applianceblog.com/mainforums/bosch/13170-bosch-shu3326uc-14-wont-drain.html
Posted By For Type Date
Bosch - Page 2 - ApplianceBlog.com - Appliance Repair Forums This thread Refback September 8th, 2009 06:09 AM
Maytag MDB6600AWW Won't Drain cyboc Maytag/Magic Chef/Admiral/Jenn-Air 2 August 18th, 2007 12:07 AM
Bosch Dishwasher SHU5315UC will not drain JVD Bosch 0 June 5th, 2007 07:24 PM
Bosch shx46b05 drain running continuously jgensler Bosch 2 May 31st, 2006 05:01 PM
Bosch SHU66 won't drain VANCOUVER Bosch 1 May 15th, 2006 03:49 AM
Another Whirlpool Dishwasher won't drain rickm Whirlpool 1 August 8th, 2005 10:11 PM
