Go Back   ApplianceBlog.com - Appliance Repair Forums > Appliance Repair Talk > Dishwashers > Bosch
Old March 4th, 2009, 08:57 AM
prop is on a distinguished road
Default bosch shu5315uc error code 4
i get code 4 when i run diagnostic.i know this is fill code.i changed the
water inlet system
the water level switch housing
water valve assembly
and now just changed the control module.it still won`t run a cycle thru.the old module showed 2 hrs on all cycles except rinse and hold and that gets stuck at 8 min.the new module shows all the different cycle time but it only counts down a minute or 2,then the water level assembly then just constantly opens and closes.the plunger just goes up and down every couple of seconds just cycling water in and out.what else can it be?thanks for any help
Old March 7th, 2009, 10:58 PM
seen the water fill diaphram fail and cause "surging" of water in, then short pump run on drain and repeat. as for washing and not advancing- check heater relay. water level regulator(includes diaphram part) #263185 $20(need to pull unit and remove left side panel- easy job).
Old March 8th, 2009, 06:14 AM
where is and how do i check the heater realay?i already replaced the water level regulator.thanks for your help
Bosch Dishwasher SHU5315UC will not drain JVD Bosch 0 June 5th, 2007 07:24 PM
Bosch SHU5315UC BluePat Bosch 3 March 15th, 2007 03:53 PM
Bosch Model #SHU5315UC, Strong odor Magic01 Bosch 4 May 18th, 2006 04:16 AM
Bosch SHU5315uc rslovak Bosch 1 February 9th, 2006 05:16 PM
Bosch shu5315uc DEAD !? Upton Bosch 3 October 7th, 2005 03:22 AM
