November 30th, 2005, 07:02 AM
Bosch SHU40 problem
Good day. My Bosch model SHU4022UC dishwasher has recently started misbehaving. All is fine until the rinse cycle begins--unfortunately, it never ends. Dishwasher fills normally and the rinse begins, but the cycle will run forever unless I advance the timer manually. Obviously, I suspect a timer problem, but perhaps someone can suggest other things to check first?
Thanks in advance....
November 30th, 2005, 10:44 PM
I'm not very familiar with Bosch.
Jeff1 has a great Bosch web page:
http://www.applianceaid.com/boschDW.html
December 1st, 2005, 04:57 PM
most Bosch machines won't advance if heat does not work correctly, check that first.
Last Post: July 2nd, 2007, 09:48 PM
Last Post: January 3rd, 2007, 08:58 AM
Last Post: June 17th, 2006, 07:23 PM
By smondazzi@comcast.net in forum Bosch
Last Post: April 11th, 2006, 07:12 AM
Last Post: February 9th, 2006, 07:06 PM
