January 5th, 2011, 11:32 AM
Pop and sparks
My Bosch tripped the circuit breaker during a cycle. I reset it and went to power on the unit and there was a spark down at the bottom. I removed the kick plate, reset the circuit breaker and tried the power button again. A pop and much bigger sparks coming out of the little box where all the wires connect together. Any thoughts on what could be causing this or a quick (and hopefully cheap) fix? Thanks!
March 10th, 2011, 06:05 AM
Did you fix the problem???? was a strain relief installed on the power cord....check the power cord to so if it has worn areas , exposing the wires to the metal box.........
