February 26th, 2011, 06:35 PM
Dishwasher starts cycle, stops, starts again, stops ect ect
Bosch
My dishwasher was recently showing all the telltale signs of the circuit board problem. Increased cycle times, cycle hanging on 1 minute and finally the dishwasher would power up and start for 5-10 seconds and shut off for five second, the start back up for a couple seconds then shut off again.
So I pulled it apart and low and below the relay was blown. I had the board re-soldered and fired the dishwasher back up and it did a normal wash at 140 minutes. Ok that seemed a little long but it did the job and washed the dishes nicely. Fired it up again tonight for the second load since the re-soldering. The display showed 111 minutes. Ok that seemed to be back to normal! Then, the starting and stopping procedure started up again???
Any idea what the problem could be as I've just had the board fixed so I'm not sure what it could be...
March 5th, 2011, 06:05 AM
March 5th, 2011, 07:42 AM
Sorry no one has assisted you as of yet, I don't know anything about Bosch or I would.
Here, you can read this link:
Bosch dishwasher helps
Jeff usually comes here in the evenings and mornings, or you can go to Jeff's forum here:
http://www.applianceaid.com/qanda.html
March 16th, 2011, 07:08 PM
It was a bad board.
By kdierk in forum Sears Kenmore
Last Post: October 17th, 2011, 10:43 AM
By CGiff9 in forum Dishwashers
Last Post: May 25th, 2011, 10:09 PM
By newuser in forum Frigidaire/Electrolux
Last Post: April 27th, 2010, 11:28 AM
By andregb1 in forum KitchenAid
Last Post: October 2nd, 2009, 08:35 AM
By eohappy in forum Sears Kenmore
Last Post: October 30th, 2008, 09:46 AM
