Results 1 to 2 of 2
Thread: Surprise! Bosch Dishwasher not draining completely
    Gmoneycrf450 is offline Member
    Mar 2011
    Sacramento, CA
    Default Surprise! Bosch Dishwasher not draining completely
    Model Number: SHE33MO2UC
    Brand: Bosch
    I have a Bosch SHE33MO2UC Dishwasher that leaves about 2" of cloudy water in the bottom after the wash cycle is completed. I pulled the entire dishwasher out last week, but I could not tell by looking at it how to remove either of the side panels or the bottom panel to get a better look at the pump. I checked the line from the vent to the garbage disposal and that was clear (that was the culprit last time it would not drain), I removed the mesh filter and the ss grate in the bottom of the dishwasher and was able to see the impeller....it would turn about a 1/4 turn and stop both directions so I'm guessing that it okay.
    I think I've read every post as it relates to Bosch dishwashers not draining on here and I think I've got some kind of blockage in the drain line. I tried backfilling the dishwasher from the drain line to see if I could fill it that way, but there may be a check valve or something asociated with that system that would not allow the water to backfeed the dishwasher.
    Any help would be appreciated....I'm pulling my hair out here. Thanks
    Oct 2004
    SHE33MO2UC
    I found SHE33M02UC43 SHE33M02UC47 SHE33M02UC48 SHE33M02UC50 SHE33M02UC52 SHE33M02UC53
    Might help...
    http://www.applianceaid.com/pdf/Ascenta-dw.pdf
  1. [FIXED] Bosch Leaking Dishwasher
    By mpadberg in forum Bosch
    Last Post: November 14th, 2011, 05:11 PM
  2. Bosch dishwasher will not finish cycle
    By MrMark52 in forum Bosch
    Last Post: February 28th, 2011, 07:53 AM
  3. Dishwasher not draining water out completely
    By gedanjj in forum Whirlpool
    Last Post: October 26th, 2010, 10:28 AM
  4. Replies: 0
    Last Post: June 30th, 2010, 03:10 PM
  5. Replies: 1
    Last Post: November 14th, 2005, 10:21 PM
