March 25th, 2011, 10:31 AM
She46co5uc - no panel but power-water not draining
Bosch
Need to get this unit back on line. Is there a reset button? Next, it did not pump all out and i drained cleared any food and the impeller is clear. There is no panel display, but when I close the door w/power button on you can hear the pump start and stop. Kind of like the engine rev'n and cuttn out!
What is wrong?
March 25th, 2011, 07:15 PM
I found 10 models that begin with those.
SHE46C05UC/??
Nope. Most appliances don't have a reset.
Checked the float? If stuck up the d/w can think it is in a flood ( leaking ) mode and runs the drain pump only. Checked the drain hose, all the way to the house drain?
March 29th, 2011, 05:01 AM
Where is the float?
Should I have a tech look @?
March 29th, 2011, 07:38 PM
Normally on the left side, facing the machine...behind the fill valve.
A good idea.
By ssruindia in forum Whirlpool
Last Post: January 20th, 2010, 11:16 AM
By jrwhitfield in forum Sears Kenmore
Last Post: November 21st, 2006, 09:31 PM
By Aston in forum Maytag/Magic Chef/Admiral/Jenn-Air
Last Post: October 15th, 2006, 09:23 PM
By Catamount in forum Sears Kenmore
Last Post: June 4th, 2006, 09:54 PM
By Honeybee in forum Sears Kenmore
Last Post: November 27th, 2005, 07:09 PM
