Results 1 to 9 of 9
Thread: [FIXED] No power
    T2C4 is offline Member
    Jun 2006
    Atlanta, GA
    Default [FIXED] No power
    Model Number: SHU5316UC/12
    Brand: Bosch
    My DW tripped the CB in the night mid-cycle, so I re-set the CB and the DW worked for a little while more, but then quit again. This time though, the CB is not tripped.
    I've read other posts where it could be the thermal fuse or possibly the door assembly switch. I'm not real good with electrical, however I have repaired my circuit board once and replaced it once.
    Oct 2004
    Check where the main power enters the d/w....bad for loose/burnt wires there....failing that then yes the door switches or power off/on switch would be prime suspects.
    http://www.applianceaid.com/dish.html#dead
  3. The Following User Says Thank You to jeff1 For This Useful Post:
    T2C4 (April 29th, 2011)
  4. #3
    Jun 2006
    Atlanta, GA
    Thumbs up Fixed!
    Yep, the power coming into the dw was fried. Took it all apart, cut off the charred wires, re-wired it all up, and wa-la. It works. Am I cool or what?
    Thanks to this repair blog, I've fixed this dw 3 times now!
    Thanks Jeff!
  5. #4
    Oct 2004
    Shut off the power.
    Remove the burnt connectors, cut back the wire so you
    get nice cleaning wiring and install new marr connectors.
    The kind you put on over the wires and tighten down the
    screw and then screw on the plastic cover. They are much
    better than the twist on marrette connectors. Black to
    black, white to white and green/ground.
  6. #5
    ivoidwarranties is offline Appliance Tech
    May 2008
    on the frying pan
    Make sure you place the new wire nuts with the closed/cone top facing upwards, too many shove them in upside down, creating a bowl for water to collect in and short out the connections (which will happen again if not done- which is also a fire/shock hazard).
    Usually caused by excess water or soap bubbles that get the wire nuts wet, and for some reason a lot of the unit's I find dont have any cover over connection box...
    *added fyi, not trying to upstage the jeff's
  7. #6
    thayes9572 is offline Member
    Nov 2006
    Minnesota
    Hi
    I too had the wiring burn and feel fine replacing it. Question is: the wiring that comes from the dishwasher (especially the black wire) got pretty fried and there is not enough current wire to connect to the incoming power line.
    Is there a kit/part I can buy to replace the positive/negative/neutral in the dishwasher, or are they just "generic" wires I can buy from a hardware store. If I can replace, any idea what gauge they are?
    Thanks, have always received good info and help from this blog
  8. #7
    Oct 2004
    None that I have seen.
    I'd try to go with a stove style wire, 14 gauge.
  9. #8
    Nov 2006
    Minnesota
    Thanks, Do you know if its easy enough to get access to the wires as releasing the screws holding the plate in place?
  10. #9
    Oct 2004
    Just release any hold downs and brackets there, shouldn't be -much- trouble
  1. [FIXED] whirlpool duet steam won't power on... no lights
    By rickerra in forum Whirlpool/KitchenAid/Roper
    Last Post: March 3rd, 2011, 06:43 PM
  2. No power to dryer, outlet and cord have power
    By dorn27 in forum Frigidaire/Electrolux
    Last Post: November 24th, 2010, 05:33 PM
  3. GE JE1260 power fuse
    By valbird in forum GE/Hotpoint
    Last Post: October 4th, 2010, 02:37 PM
  4. GE Front Load won't complete cycle(s)
    By prostuff1 in forum GE/Hotpoint
    Last Post: July 14th, 2010, 03:39 PM
  5. Kenmore HE4t - F02 then no power
    By zzyzx in forum Sears Kenmore
    Last Post: April 25th, 2010, 10:40 AM
