Results 1 to 7 of 7
Thread: Bosch Dishwasher SHX33A05UC/21
    gtwins is offline Member
    Mar 2011
    Michigan
    Default Bosch Dishwasher SHX33A05UC/21
    Model Number: SHX33A05UC/21
    Brand: Bosch
    I having problems with the door opened I turn On the power and the drain keeps running. I pulled the screen off at the bottom and noticed it is was dispensing water also.
    Oct 2004
    Are you saying something is running with the door open? Door switch should prevent this. With the drain pump running all of the time, need to check the float to make sure it is not stuck up or that a leak hasn't put water into the base causing the float to rise and turn on the drain pump.
    If needed:
    Door latch & strike plate, with microswitch
    Mar 2011
    Michigan
    Hi Jeff
    I took the screen off and I disconnected the drain hose from the disposal then filled the base with water and it drained good. When the base drained down I noticed a small leak is this normal. and yes when I leave the door opened and turn on the power the pump turns on.
    Mar 2011
    Michigan
    Default Bosch
    Jeff,
    I let the pump run for a few minutes and watched with the screen off and saw water coming from a small hole. Is it possible that there is a valve under the unit that am be stuck open causing a small stream of water?
    Oct 2004
    The base of the d/w?
    No leaking is normal. If the base of the d/w gets water in it the float will rise up and trip making the drain pump run all of the time because the d/w thinks it is in a float mode.
    Doesn't sounds like the door switch os working properly.
    If you disconnect power from the d/w and water still is weeping in then yes the fill valve can be mechanically sticking open and needs replacing.
    Water inlet valve
    Mar 2011
    Michigan
    Default Jeff
    Sorry for the inconvience but i decided to video tape and post it on youtube for you to see. Here is the link YouTube - ‪MOV04035.MPG‬‏ please if you can help i would really appreciate it.
    Oct 2004
    Ok...same as before...apears the drain is running because the float is tripped...find out why!...water in the base, bad float, bad float switch, etc.
    Water moving around in the sump is normal when one or both os the pumps are running.
  1. [FIXED] Bosch Leaking Dishwasher
    By mpadberg in forum Bosch
    Last Post: November 14th, 2011, 05:11 PM
  2. Replies: 1
    Last Post: March 16th, 2011, 07:21 PM
  3. Bosch dishwasher will not finish cycle
    By MrMark52 in forum Bosch
    Last Post: February 28th, 2011, 07:53 AM
  4. Rinse Light Flashes
    By C6Silver in forum KitchenAid
    Last Post: August 1st, 2010, 03:05 PM
  5. Bosch dishwasher
    By 070725julia in forum Bosch
    Last Post: December 28th, 2007, 10:52 AM
