Results 1 to 4 of 4
Thread: Need access to wiring for dishwasher
    thayes9572 is offline Member
    Nov 2006
    Minnesota
    Default Need access to wiring for dishwasher
    Model Number: SL84A302UC
    Brand: -major brand-
    Age: Less than 1 year
    Hi
    As a follow up to this week, I need to fix the power wires from the dw as when wires shorted last week, the black, power wire became unusable as is, so I need to replace it. I cant seem to find out where or how to access the other end of the power (black) wire that carries the power.
    Tom
    Oct 2004
    Got nowhere with that model#. Please recheck.
    Is the wire diagram missing from the unit? Might help point to where that wire is heading towards.
    Nov 2006
    Minnesota
    Thanks, will check the model number. Its the main black positive wire that you use for powering up the unit. When the wires "melted" the wire burned v=back to far to rewire, so I am trying to find out where it originates so I can replace it. Where would I find the wiring diagram?
    Oct 2004
    Normally folded up in the base at the front behind the access panals.
  1. Wiring diagram for Matsushita D91C18RAW5.
    By Twano in forum Refrigerators & Freezers
    Last Post: February 20th, 2011, 08:16 PM
  2. Jenn Air Icemaker wiring harness questions
    By rcrosier in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: January 29th, 2011, 05:59 PM
  3. [FIXED] Washing Machine Motor Upgrade Wiring
    By billyjoe46 in forum GE/Hotpoint
    Last Post: October 16th, 2008, 08:00 PM
  4. Detergent Door will not open! Need wiring diagram.
    By Bob Swerski in forum GE/Hotpoint
    Last Post: July 10th, 2006, 10:12 PM
  5. replacement wiring harness for relay/overload combo
    By jedi4x4 in forum Sears Kenmore
    Last Post: October 25th, 2005, 07:18 AM
