Results 1 to 4 of 4
Thread: Bosch SHU33 dead but has power
    nboich is offline Member
    Aug 2011
    Florida
    Default Bosch SHU33 dead but has power
    Model Number: SHU33A06UC/46
    Brand: Bosch
    The dishwasher does not respond to the on/of switch or the three cycle buttons. It stopped working in the middle of a cycle a couples days ago and now it seems dead.
    Pressing the cancel & drain buttons doesn't seem to do anything.
    It does have power where I wired it into the front lower left of the unit.
    I removed the impeller cover and the impeller moves freely. I pulled out the unit and removed the left side cover. There's something like a float switch there; if I push it up, the pump does work and will drain the tub. But the unit will do nothing else.
    Thanks in advance for your suggestions.
    Oct 2004
    Accross the 2 wires? What was the reading?
    Bad house fuse/breaker, burnt/loose wire nut where the power enters the d/w, broken wire in the door ( esp where it bends to open and close ), bad start switch are common trouble makers.
    Aug 2011
    Florida
    Thanks Jeff. It had 112v across the incoming wires.
    Oct 2004
    Quote Originally Posted by nboich View Post
    Mildly low, 115-120 would have been better.
    When voltage drops the amps increases and we can burnt off wires.
  1. dishwasher dead - possible power surge prior
    By themaninthewoods in forum Sears Kenmore
    Last Post: March 7th, 2011, 04:27 PM
  2. Bosch SHX57C won't power up
    By berrytc48 in forum Bosch
    Last Post: November 16th, 2010, 04:41 PM
  3. Replies: 5
    Last Post: August 16th, 2010, 08:54 AM
  4. Bosch Dishwasher Power
    By 10009575 in forum Bosch
    Last Post: October 11th, 2007, 04:38 AM
  5. Bosch shu5315uc DEAD !?
    By Upton in forum Bosch
    Last Post: October 7th, 2005, 03:22 AM
