Results 1 to 8 of 8
Thread: bosch SHE45m02UC/50 not draining
    smartin36 is offline Member
    Aug 2011
    new jersey
    Default bosch SHE45m02UC/50 not draining
    Model Number: She45mo2uc/50
    Brand: Bosch
    My bosch d/w has stopped draining. It started as an intermiitant problem but now it does not drain at all. I inspected the drain pump impeller moves freely, the drain hoses are clear and raised up above the plumbing drain and the check valve is clear. I also noted that the last few times I tried it the timer display was much longer than normal when the unit was first turned on. When it is time in the cycle for the unit to drain, there is a relay clicking sound from the control panel but no pump noises. Then it starts pumping water around like a rinse cycle until the timer counts down and shuts off. I inspected the control board and did not find anything unusual. Any ideas?
    Oct 2004
    Power to the pump motor when it should be draining but is not is a pump issue.
    No power to the drain pump when it should be draining is a control or wire between the control and pump issue.
    Aug 2011
    new jersey
    thanks for the responce jeff. I have not verified if there is power to the pump, only that the impeller spins freely. I dont have a wiring schematic or test proceedure for this model. Are there test proceedures that will allow me to get the controll board to call for draining so I can test the pump voltage? I assume that it is a 110 vac pump motor. I would like to put the unit in drain mode and test for voltage at the board output, but I dont know which terminals and how to make the unit drain without running through a full cycle.
    Oct 2004
    Normally folded up under the unit at the front.
    All d/w's will fill, swoosh the water around and then....drain. Just have the meter leads in the wire connector going to the drain pump.
    These may help...
    http://www.applianceaid.com/pdf/SHU4...36-service.pdf
    http://www.applianceaid.com/pdf/SHE44C06UC22.pdf
    Drain pump
  5. The Following User Says Thank You to jeff1 For This Useful Post:
    smartin36 (August 15th, 2011)
  6. #5
    Aug 2011
    new jersey
    Thanks jeff that gives me something to go by
  7. #6
    Oct 2004
    Your welcome
  8. #7
    Aug 2011
    new jersey
    the info you sent was just what I needed. The problem is the drain pump. Thanks again
  9. #8
    Oct 2004
    Thankx for the update
  1. [FIXED] Bosch Leaking Dishwasher
    By mpadberg in forum Bosch
    Last Post: November 14th, 2011, 05:11 PM
  2. Replies: 1
    Last Post: March 16th, 2011, 07:21 PM
  3. Bosch SHE68M not draining or resetting
    By Atenas in forum Bosch
    Last Post: December 2nd, 2010, 02:57 PM
  4. Replies: 0
    Last Post: June 30th, 2010, 03:10 PM
  5. Replies: 1
    Last Post: February 17th, 2009, 05:52 PM
