Page 1 of 4 123 ... LastLast
Results 1 to 10 of 31
Thread: Bosch will not start a cycle
    ctames2 is offline Premium Member
    Aug 2012
    United States
    Default Bosch will not start a cycle
    Model Number: SHE66C06UC
    Brand: Bosch
    My Bosch was showing 52 minutes left in cycle the other day but no noise was being made. I opened the door and it turned on, sounded like it was trying to pull out water although there was no sitting water inside.
    I reset the machine (held the two 'cancel drain' buttons down) and opened the door and hit "off". the machine turned off as normal and i tried a new load using regular cycle. the minutes showed on both the LED on front and on the top of the door, as usual, but when I closed the door the LED minutes on front shut off after a few seconds. It continued counting down as normal on top of the door but the machine itself wasn't doing anything, basically just counting down the minutes. When I opened the door that original noise of the machine trying to pull out water returned although it never even went into a presoak or any other cycle
    Oct 2004
    Float tripped and the d/w is thinking it is in a flood mode?
    Float and float switch are normally behind the fill valve ( left side facing the d/w )....and yes often we have to pull the d/w out to access.
    http://www.applianceaid.com/
    NEW Appliance Repair Aid
    http://www.jrappliance.ca
    JRAppliance
    Aug 2012
    United States
    thanks for the reply. checked the float and was in good condition and switch registering correct ohms. water level switch works fine too. checked the switch on door and works correctly both open and closed.
    strange thing is that the machine stops working when door is closed but attempts to work with door open.
    not sure what else to check but must be something in control panel?
    Aug 2012
    United States
    hi jeff. i saw on another forum a guy with my model and pretty much the exact same issue and the advice was to change out the water valve. when i had the side open and was testing the unit there was water bubbling out of the chamber (clear with 3 hoses running into it). does this seem like the possible fix?
    Aug 2012
    United States
    jeff, tested the water valve solenoid and it registered .988k ... i understand this doesn't mean the valve is OK but just giving you as much info as possible. thanks for the assistance
    Oct 2004
    SHE66C06UC
    Missing a couple of digits.
    I found SHE66C06UC22 uses valve...
    Bosch will not start a cycle-water-inlet-valve-425458-00652897.jpg Water inlet valve Manufacturer Number 425458
    And SHE66C06UC46 uses fill valve...
    Bosch will not start a cycle-water-inlet-valve-607335-01066918.jpg Water valve Manufacturer Number 607335
    And no the valve shouldn't be weeping in water all of the time. That can/could still trip the safety/float.
    Hopefully the door open/closed issue doesn't indicate a door switch problem. For sure do the valve and see what happens then.
    JRAppliance
    Aug 2012
    United States
    SHE66C06UC / 40 is my unit. will replace the water valve then let you know
    Aug 2012
    United States
    My valve looks like the 22 above although it's a 40. I'll call Bosch in the morning.
    Oct 2004
    Looks like at 46 they made a change.
    JRAppliance
    Aug 2012
    United States
    Hi Jeff
    Replaced the water inlet valve and nothing changed. Pulled out the control board and then the PCB but didn't find any soldering errors or burned points. What do you suggest for next step?
    KF
  1. Bosch dishwasher fills but does not start
    By dieselgg in forum Bosch
    Last Post: October 20th, 2011, 05:33 AM
  2. Bosch Washing Machine will not start
    By Dominook in forum Washers
    Last Post: April 22nd, 2011, 05:56 PM
  3. Bosch SMU4052UC/14 stuck in cycle
    By rlsmith in forum Bosch
    Last Post: August 2nd, 2010, 12:16 AM
  4. Replies: 1
    Last Post: July 18th, 2007, 11:14 AM
  5. Bosch D/W won't start
    By mettlehed2 in forum Bosch
    Last Post: July 13th, 2005, 04:39 AM
Tags for this Thread
