April 16th, 2006, 09:36 AM
Bosch dishwasher, do dishes really dry?
I am purchasing a new dishwasher. Cost is not the main driver, I would prefer the following features;
1. Cleans dishes without washing before I load them
2. Quiet
3. Adjustable racks
4. Ability to handle large diameter plates
I have been told that the Bosch dries very well with no heated dry cycle and I have been told that dishes are always wet. Who is correct?
The other dishwasher that I am considering is an Asko. Any comments on Askowould also be appreciated.
April 17th, 2006, 05:17 AM
Just uses the heat built up from the hot water.
Most today will dry flat dishes and such no problem...anything with a divet on the bottom ( glass cup ) will have water laying in the indent. Using jet-dry helps with the dry cycle also.
*I* won't be owning one...JMO!
April 17th, 2006, 04:12 PM
Water temp above 135 helps, purge the water from your sink before starting dishwasher so the hot water is up to the dishwasher location. Water hardness should be reasonable, jet dry, etc, etc, etc...
Buy a kitchenaid.
April 22nd, 2006, 06:23 PM
Most dishwashers recommend running the faucet before starting and if you dont rinse off or scrape off good you will just be cleaning the screen/sump often..
October 4th, 2006, 03:15 PM
Drynot
They truly do not dry anything as well as less "exotic" models that I have owned. Everything else is superior, but the drying function leaves a lot to be desired.
By pointnshoot in forum Bosch
Last Post: April 21st, 2011, 10:45 AM
Last Post: July 2nd, 2007, 09:48 PM
By laroc in forum Maytag/Magic Chef/Admiral/Jenn-Air
Last Post: March 5th, 2007, 10:54 AM
By sparks70b in forum Bosch
Last Post: October 11th, 2006, 06:12 PM
By Bemidji1 in forum Whirlpool
Last Post: August 8th, 2005, 10:52 PM
