June 10th, 2007, 08:22 PM
Bosch Dishwasher Problem
Hi -
I have a Bosch dishwasher SHU43C05UC/22 that will not run.
It was working fine about two weeks ago, then I went on vacation, returned yesterday & saw that some water was leaking out the front. Opened the door, and the reservoir was full of water. I've seen this before, usually just run a load & all is fine. Tried that this time but it got stuck on "38" with pump runing continuously. Turned it off, then tried to run it again - it finished the cycle but no water ever was used - detergent dry on dishes. And, still running in pump mode if I turn it on. It'll pump water out if I pour in with a pitcher. I did find the very helpful electronic test that you've published, but this dishwasher does not respond like the sequence shows. Instead, "C1" comes up, then "PO," and then one light blinks above the "Rinse & Hold & "Quick Wash" is steady. When I start the test, both "Regular Wash" & Quick Wash" are blinking. Any ideas?
DanM.
July 2nd, 2007, 09:48 PM
Did you ever figure out what was wrong?
We're having the exact same problem - did you ever figure out what the problem was?
By pointnshoot in forum Bosch
Last Post: April 21st, 2011, 10:45 AM
By sparks70b in forum Bosch
Last Post: October 11th, 2006, 06:12 PM
Last Post: April 11th, 2006, 05:04 PM
Last Post: December 1st, 2005, 04:57 PM
Last Post: April 16th, 2005, 05:48 AM
