Looking for any information regarding a problem this particular frig had with the ice maker. Apparently, a diode sensor that was linked to the wire harness went bad and caused ice to dispense randomly. I'd like to find a memo that was sent out by Frigidaire about 2 1/2 years ago to all their authorized service and sales centers that detailed this problem. There was never a recall. I would also like to find the part number for the diode sensor.
Frs26h5as
I have changed a couple of these so far this year, I even had to call our Frigidaire tech. line to get the part numbers. All i can advise you to do is call: Frigidaire 1-800-451-7007 USA Frigidaire 1-800-668-4606 Canada Jake
I called them first, but they were no help. Do you know the part # for the diode senser? Do you have the service bulletin that Frig issued?
You can try at Repairclinic.com they deal with all appliance parts.
I don't have a service letter, sorry. Jake
I found some additional info. The problem is actually with the ice maker. Apparently, when the ice maker cycles and water starts filling it up, the water also runs through the water dispenser causing a flood of water to run out of the freezer door and onto the floor. Tech says the water valve diode is shorted. Do you have any kind of service bulletin on this?
Diode repair kit, water valve wire harness Part# 5304418384jeff.
Thanks for the info. My full model # is FRS26H5ASB8
I checked that full model# you listed, it does not even show a diode assembly, unless i missed it somewhere.
That kit Jeff1 posted should do it though. You can click on Jeff1's link and before your order it just ask repairclinic.com to make sure that one matches your model#. Jake
Most of the parts breakdowns don't show them....but they are on the wire diagram for that model....
Diagram link jeff.
| Whirpool Conqest Gold Side by Side Ice Maker Problem | tadpole88 | Whirlpool | 13 | September 21st, 2007 12:29 PM |
| Ice Dispenser Problem | dmz | Amana | 7 | May 27th, 2007 12:17 PM |
| GSH25KGMC Water Dispenser Problem | TripleJackInGA | GE/Hotpoint | 1 | February 2nd, 2007 11:54 PM |
| another Ice Maker problem | KC73 | Sears Kenmore | 1 | September 14th, 2006 12:54 AM |
| Whirlpool ED22DQ/RQ Ice Maker problem | Rich46 | Whirlpool | 5 | September 11th, 2005 10:16 PM |
